HEI in 82 bronco
an hei is a gm but they make an hei on a ford body
http://www.speedwaymotors.com/p/7518...tributors.html
Did your HEI dizzy come with any instructions? The one I have on my 460 did. I can't help much with advice, since I'm also using a universal wiring harness with a dedicated and marked "coil" power wire. You can look up the wiring diagrams in the haynes manual and find what color wire powers your coil. then you can remove all the other 'junk' like the ignition module used on the old DuraSpark II igniton in your 82 Bronco. JSM84
I ran across this link to the HEI install while looking for other stuff. It's for a Jeep, but has some good info in general:
http://www.offroaders.com/info/tech-...ct-cj7-HEI.htm
ola1234
05-01-2022 02:08 PM
hail destroyer
27
06-16-2018 09:46 AM
351Cleveland C4
19
08-20-2013 07:12 PM
