Hello All...
I have just installed a new TCI competition C6. Reverse manual valvebody with a transbrake. I have wired everything in. I have a B&M Mega Shifter with the B&M T-handle shifter knob with a button. I have wired the botton to a 12V source with the other end of the circuit going to the transbrake connector on the top of the valve body housing on the case. My question is with everything else on the truck turned off (engine not running) should I hear something happen when I hit the button? I.E. does the thing make some kind of noise when it operates? I have never had one and have never known anybody that has a transbrake so my knowledge is a bit limited. I just wanted to make sure I have it hooked up right before I take it out for a first try. Any thoughts you have are appreciated. You may see this beast at
www.MrScharfenberger.com/F100
Thanks!!
