Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-19-2008, 12:51 PM
jonesg is starting off with a positive reputation.
1995 E350 cat converter loose
95 E350 van, the exhaust is loud,
the flange joint ( looks like this -][- )
in front of the cat has 3 nuts broken off, tried to knock the bolts out but I think they must be welded studs? The only one left holding it together is on the top, I could cut/grind that off easy enough and drop the front section, could I then drill out the studs and replace with stainless nuts/bolts ?
The cat is still good and I don't want to pay for a new one if the mounting can be fixed on the old one.
I don't have any way of getting the cat seperated from the rest of the system so I'll have to do everything under the van (the tailpipe goes over the axle) . unless...
Is it possible to hacksaw thru the pipe behind the cat, fix the broken studs (drill em out on the workbench) and then reconnect the exhaust pipe again with a slightly oversize pipe and clamps?
I need to get this done as inspection is coming up in 2 weeks.
The exhaust system looks fine otherwise.
Sponsored Links
To remove this ad, register today!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
