Stainless Steel Lug Nuts? - Page 2 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 01-19-2008, 10:23 PM
97 HD's Avatar
97 HD 97 HD is offline
97 HD is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by 73strokin
I would think that the stainless would be fine. I think it was either 303 or 304 that the hex stock was sold in. I'm sure standard lug nuts are heat treated some, but stainless itself is harder and stronger than standard steel just because of its properties and manufacturing. I'm not an expert on metallurgy but from basic knowledge that's what I'd conclude. I would think before you have problems stripping threads or wearing down nuts you would probably start snapping studs off first.
I just wanted to throw it out there for something to think about.
Old 01-19-2008, 11:51 PM
73strokin 73strokin is offline
73strokin is starting off with a positive reputation.
Quote:
Originally Posted by tjbeggs
how about these
http://store.summitracing.com/partdetail.asp?autofilter=1&part=GOR%2D76197XL&N=7 00+400092+4294919065+115&autoview=sku
Gorilla claims a lifetime warrantee. They cost about 2 1/2 times more than the chrome one I currently have but atleast they might last.
These are actually the nuts that I have that are rusting. Chrome plated steel. Not impressed with them at all. And a lifetime warranty? How many times will they uphold this warranty and will they honor it if they can tell you used an impact? It says right on the box: Do Not use an impact wrench! Who's going to listen to that? Especially at a shop. Some questions I thought I'd throw out there to ask yourselves. Personally I'd rather just do it right and go with stainless, whether I can buy them or have to make them.
Old 01-19-2008, 11:56 PM
Quote:
I totally agree. If anybody with some metallugy background would see a need to heat treat the stainless, feel free to chime in.
Old 01-25-2008, 09:13 AM
97 HD's Avatar
I asked arround, and all of the metal "experts" I know say that stainless would be fine by itself, no heat tempering required.
Old 01-25-2008, 05:09 PM
Thanks for the info. I figured that the stainless would be fine but it's good to have some extra opinions. Now I just have to order the tap and stainless and make a prototype! I've never turned stainless before so I'll have to see how it's going to cut.
Old 02-02-2008, 09:57 PM
MTNWOODY's Avatar
MTNWOODY MTNWOODY is offline
MTNWOODY is starting off with a positive reputation.
Gorilla makes SS lugnuts in 9/16" x 2" and 2.4" the part numbers are 96197(8)SS and 96197(8)XLSS. I am guessing the difference as to whether the part number ends in 7 or 8 is the packaging and number of lugs? I am trying to find a price. I would like to remove my center caps and sell them when I get new tires. Then, add the SS lugs. 2" or 2.4"?
Old 02-02-2008, 10:08 PM
ozzy460's Avatar
ozzy460 ozzy460 is offline
ozzy460 is gaining momentum as a positive member of FTE.
i work in a welding/ machine shop, only prob we have found with using stainless nuts against steel bolts is if they are overtightened( which is common) the stainless will sometimes gall or strip and the nut will become jammed, and either strip totally or twist the lug or bolt off, only seems too be a problem if its over tightened, but work fine otherwise, just something to think about.
Old 02-02-2008, 10:56 PM
MTNWOODY's Avatar
I have an e-mail in to Gorilla for pricing. When they reply I will inquire about any potential problems. I am sure they have their liabilities covered by excluding the use of impact wrenches and torque specs. I'll ask tho. Sounds like my local tire shed (seriously, a big shed) would have to be reminded to torque by hand when they rotate if I go with the SS.
Old 02-02-2008, 11:45 PM
Mark62's Avatar
Mark62 Mark62 is offline
Mark62 is starting off with a positive reputation.
I do not believe that SS heat treats like carbon steel...
Old 02-02-2008, 11:46 PM
Mark62's Avatar
Quote:
Use a copper or silver compounded anti-sieze to stop this...
Old 02-03-2008, 07:08 AM
Those Gorilla nuts are something to look into if they are indeed SS without chrome plating. I have Gorilla nuts now and they must be just chrome plated steel, because they are starting to rust. My whole intent behind stainless steel nuts was to make a nut that would hold up appearance wise without a coating. Because sooner or later any coating is going to break off or crack, whether an impact is used or not. And lets face it, most of us, and probably all shops are going to use an impact to change lug nuts. Reguarding the galling/stripping of the stainless, I have not heard of this, but the antiseize compound might be a good idea as long as it doesn't keep the nut "too loose" and allow it to work its way off.
Old 02-03-2008, 08:12 AM
ozzy460's Avatar
Quote:
yea never thought of that
  #28
Old 02-03-2008, 09:55 AM
Mark62's Avatar
The Stainless galls and strips the thread off of the Carbon steel part(if your lucky it comes apart) otherwise it seized up completely and you have to break the stud.
The problem that causes the seizing is garbage on/in the threads. clean the lug nut and stud before assembly. I have seen Teflon Coated SS bolts seize going into carbon steel...
  #29
Old 02-03-2008, 10:58 AM
MTNWOODY's Avatar
Check out the pictures in this link. I believe their "SS" lugs are sleeved...probably with steel.
http://www.gorilla-auto.com/lifetime.lug.nuts.stainless
  #30
Old 02-03-2008, 10:51 PM
Mark62's Avatar
It plainly states SS body with Chrome Vanadium steel seating surface...
Looks to me that the only part that is SS is the Cap.....
F250 Lug Nuts and STUDS.!!!!!!!!! bignewf 1987 - 1996 F150 & Larger F-Series Trucks 5 04-21-2016 01:31 PM
Saltwater = Frozen Lug Nuts djed 1999 - 2003 7.3L Power Stroke Diesel 51 06-12-2015 04:29 PM
Lug NutZ truck7575 Excursion - King of SUVs 3 05-21-2013 06:34 PM
Got some new Gorilla lug nuts AMG-SM 1999 - 2003 7.3L Power Stroke Diesel 7 12-25-2012 02:34 PM
Lug nut covers for DRW Kep4 6.7L Power Stroke Diesel 3 10-30-2011 07:28 PM
Tags
02, 916, f150, f250, ford, long, lug, metallurgy, nut, nuts, rusty, stainless, stainlesssteellugnuts, steel, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
