Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-19-2008, 05:27 AM
blue ox is starting off with a positive reputation.
Oil System Modification
All,
Thanks in advance. I saw a few pics on the internet of an oil system mod done to a 460. It included drilling holes through the cylinder head and block at an angle into the front timing chain cover to help lubrication. It also showed opening up the rear oil holes for faster drain back. Does anyone know what site that is or has anyone done these mods? Are there any better mods to the 460 oil system other than these?
Bob
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-20-2008, 04:26 AM
gearhead351 is starting off with a positive reputation.
Other than a tight rebuilt motor, block cleaned and oil passages!, a high volume pump will have almost the best oiling.
The only timing chain lub way I heard was the plugs at the galley next to the side of the cam. Some people drill a tiny hole in the plug and its sprays oil out onto the chain to keep it very lubricated.
The drain back is really only needed if its a high revving motor. They say that because a HV oil pump will run the pan dry. But figure only doing that past 5000rpm for LONG periodes of time.
Ive personally never expierience it. I run my 351 windsor with a high voume pump up to 5500rpm and hasnt ran it dry. Stock pan.
__________________
"Speed costs money, How fast do you wanna go?"
"rumor is you could F**K up an iron ball with a rubber hammer"
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
