1978 F350 with 460 Ignition Timing and Idle RPM
I have a 1978 F350 Ranger XLT, 2WD, with a 460, and the 4 barrel holley carb. The emissions control label is long gone.
I'm trying to find the specs for Ignition Timing and Idle RPM. Web searches haven't turned up any useful information.
Do any of you have this info? Thanks in advance.
Welcome to the site
I can help you.
Your Calibration code for that engine is
8-97-R0
Go to this page and Scroll down to the 2nd last row of specs to find yours
http://www.clubfte.com/users/mil1ion...e-upSpecs.html
Bonus for you:
This page shows your emissions hose routing
http://i69.photobucket.com/albums/i7...97-R0nonac.jpg
I can help you.
8-97-R0
Bonus for you:
Dennis,
Thanks for the info, that is a lifesaver. I should have put this in the earlier question, but do you know if the vacuum hose is to be removed from the distributor vacuum advance when setting the timing. Some info I did find implied that sometimes you remove it, and sometimes you don't.
Thanks again.
Dave
Thanks again.
Dave
Sorry to bump this thread from the dead, but didnt want to start another one. Dennis, is that chart you referenced applicable to a 73 f250 w/ a 460 also? Somehow I ended up setting the timing at about 9-10 with the vacuum advance disconnected from the dist and plugged, and the truck has a terrible time starting up. Got the info from here (this site), but dont remember how long ago or from whom ( I have been on 2 cruises back to back and am getting ready for another one, and just havent been around much.)
Thanks,
jamie
Thanks,
jamie
Try retarding the timing back to 4* or so, see if that helps. Also, is your truck points or electronic ignition? I think the 460 that year was the first to get the electronic ignition.
If you copy the link Dennis posted, and remove the file name, that will show you the listing of all of the items he has uploaded. You might find what you need there, or at his FTE site http://mil1ion.clubfte.com/FordRelatedLinks.html
1978crewcab
04-12-2016 12:05 PM
1978crewcab
04-07-2016 06:03 AM
lasthighboy
09-26-2010 11:37 PM
Craigwell
01-05-2010 01:35 PM
