Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 01-21-2008, 05:25 PM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.
Read this one then.
Quote:
Originally Posted by AndysFords
I bought NEW injectors and a rebuilt Injection pump from Diesel care, and the injectors are still doing great. The pump, on the other hand, not so good. The pump they sent me was no good, and I had to send it back, then the next one they sent me, it shot fuel out, but the engine didn't seem to want to crank, It finallly cranked up and seemed to do good, but anytime it set all night, it was hard cranking. A month later, it was at Ford having the steering column rebuilt, and that pump went bad. I had the guy at the Ford place order me a rebuilt one from a pump shop he knew of that offered a one year warranty good at all Ford dealers, and I've been good ever since. Let me say, however, that the people at Diesel care are very nice people. They were always willing to work with me, and even though there policy is no money back, they even gave me a full refund when I explained that I just did not have time to wait on a another pump to be shipped in from them since I needed the truck. Very great people, i just would not trust their stuff.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 01-21-2008, 05:34 PM
bigblu78's Avatar
Hard On Equipment
bigblu78 is starting off with a positive reputation.
I will second that quote from AndysFords. I had a very similar experiance with a Diesel Care pump. Every since I started using only MWFI parts. It helps that they are only a couple of hours from my house as well. Great group of guys up there.
__________________
88 F-250 Ext Cab 4WD
Dana 60 Solid Axle 4:11, Dana 60 Rear Discs 4:11, Hydo-Boost Brakes (Currently under the knife!)
At least one old IDI laying around at any time!!
97 Dodge Ram Ext Cab Short Bed 4WD Auto
Illinois Chapter Member
  #18 (permalink)
Old 01-21-2008, 05:59 PM
Changing three injection pumps in a little over a month?
I won't think twice about spending double what Diesel Care wants for an IP.
My truck has to run every day.
It has to start every time I turn the key, even if the temp is 20 below.
There have not been very many times that it has let me down since 1986.
Most of those days were the result of a reman engine that I tried.
Fired right off at 2 degrees this morning.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #19 (permalink)
Old 01-21-2008, 08:37 PM
PLC7.3 is gaining momentum as a positive member of FTE.
FYI my rebuilts were other than the outer shell........ new. The pintle assy is brand new, only the body is used at least on mine. Even so the pressures did need to be matched for a good "set"....... A good matched set will be a max difference of 5 PSI only......
__________________
93 F250 SC 4x4 E4OD 355LS
  #20 (permalink)
Old 02-17-2008, 08:38 AM
petepetersen is starting off with a positive reputation.
How is that IP from Dieselcare holding up ? What mods did they make ( Viton seals ? anything else ? - Thanks
Quote:
Originally Posted by dyoungen
J Tata
I bought an injection pump out of memphis for $375.00 exchange. This IP is designed for use with Biodiesel. $325 without Biodiesel exchange.
http://www.dieselcare.net/FORDPRODUCTS.html is the website.
  #21 (permalink)
Old 02-17-2008, 11:00 PM
dyoungen is starting off with a positive reputation.
The injection pump I bought from Dieselcare is running fine. Once I got it running, (my fault it took so long) I've had no problems. I made 2 trips to Ohio. One the week of thanksgiving and one the week of Christmas. I've run petro Diesel, Biodiesel and SVO. The only changes I know they made is they used viton seals for the Biodiesel. I can't complain since I've had no problems.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
