Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-18-2008, 08:04 PM
78fordranger is starting off with a positive reputation.
73 250 manual everything
I dont mind manual steering and brakes but what can I do to make it easier with out adding a power steering pump is there differnt gear ratios for the box? also on drums in the front and closed knuckle 44 what other options do I have for this. Would a newer 44 work with disc or are drums fine with 35s tires. can a booster be added behind the master to give better braking? I know on semi truck they have drums all around so I would think with a booster the brakes would be efficent.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-18-2008, 08:15 PM
masterbeavis's Avatar
masterbeavis has a good reputation on FTE.masterbeavis has a good reputation on FTE.masterbeavis has a good reputation on FTE.
You can put in a brake booster, but I would also upgrade to (at least) front disc brakes. Drum brakes work ok, but they bring teh suck when you get them hot, or wet. I do not know about making your steering any easier with a different ratio on the box, myself personally, I would upgrade to power steering from a 77.5-79 F250 4x4, providing your truck is a 4x4 (I assume by your post) With 35s, and manual steering, you can convert to a custom "Armstrong" steering unit. Yer Armstong after you drive that truck a few months.
__________________
Tony
Quando omni flunkus moritati - when all else fails, play dead.
If I posted something useful, click the in that post.
  #3 (permalink)
Old 01-18-2008, 08:19 PM
JBradley500 is starting off with a positive reputation.
you could put a tractor trailer sized wheel on it. im not sure how youd fit under it but it could only help make it easier to turn.
__________________
New Plan...
410ci, 10:1, AFD 57cc 2v Heads, Edelbrock Intake and Phenolic Spacer, 725 cfm Road Demon, Roller 219/222 @.050 .535 lift 108 lsa, Bee-Hives, Dual Roller Chain, ARP's, MSD Pro Billet, Hedman Headers, Milodon Pan and HV Water Pump.
  #4 (permalink)
Old 01-18-2008, 08:24 PM
Just wanted to make it easier for my wife to drive. ( on occasion)
  #5 (permalink)
Old 01-18-2008, 08:37 PM
Buy her a Geo Tracker. Seriously tho, I do not know your wife, but if she is like mine, if it doesn't steer without fighting it, it wanders all over the road, and the brakes are scary, she will NOT drive it.
__________________
Tony
  #6 (permalink)
Old 01-18-2008, 11:38 PM
slaid is starting off with a positive reputation.
I put a steering knob on my 73 manual everything it has 36's so not real fun. The knob works good but you have to use it or it could do some damage to your arm.
  #7 (permalink)
Old 01-18-2008, 11:44 PM
ferrwrench is starting off with a positive reputation.
Pushups!!!!!
__________________
See the happy moron he doesn't give a damn..I wish I were a moron..my god!! perhaps I am.
  #8 (permalink)
Old 01-19-2008, 04:22 PM
Broken40's Avatar
Broken40 is starting off with a positive reputation.
Sissy's i have all manual ford myself and i can stear it just fine...lol
__________________
4wd 73 F-100 390 FE, 7" lift
WARN hubs 4 bbl Eddies Carb
2wd 79 F-100 351W, C-4 tranny. 4 bbl Eddies carb
"What doesn't kill ya only makes you stronger"
  #9 (permalink)
Old 01-21-2008, 01:16 PM
Quote:
You callin the posters wife a sissy?? Ya never know, she might show up and whoop your arse in an arm rassling contest.
__________________
Tony
  #10 (permalink)
Old 01-21-2008, 01:57 PM
Broken40's Avatar
whoops
Quote:
I some how missed this post....my bad. lol
__________________
  #11 (permalink)
Old 07-13-2008, 06:04 PM
Okay I got a 78 truck now so what is envoled in getting the 78 d44 disc under my 73? I will worry about the power steering later just want to get it under her and back on the road.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
