Keeper Bull Rings....Anyone used them? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-18-2008, 12:00 PM
dwilliamsceg dwilliamsceg is offline
dwilliamsceg is starting off with a positive reputation.
I have an 08 F250. I am thinking about installing the following tie downs. Any thoughts? Anyone have these?
http://www.amazon.com/exec/obidos/tg...X0DER&v=glance
Dave
Old 01-18-2008, 12:18 PM
donjamer's Avatar
donjamer donjamer is offline
donjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputation
Quote:
http://www.amazon.com/exec/obidos/tg/detail/-/B0000AVZMU/ref=ord_cart_shr?%5Fencoding=UTF8&m=ATVPDKIKX0DER& v=glance
Dave
I looked at those but didn't choose them because they look like they would be hard to use.
They look to small to easily tie the rope off of.. I usually use 3/8" rope and that looks like you would only be able to get 1 wrap through the loop.
Also I live in MA and I am sure they would freeze in place during the winter months rendering them useless..
What I did was get the Putco Boss locker bars because they have a large area for tieing off..
http://www.goputco.com/putco_locker_side_rails_boss.asp
Old 01-18-2008, 12:38 PM
ToughBuiltFord ToughBuiltFord is offline
FTE Sponsor
ToughBuiltFord is starting off with a positive reputation.
Donjamer brings up some good points. Those will probably work, but if you want something sturdier and more reliable I would go with a set of bedrails.
Something like this: http://motorhaven.autoanything.com/bed-caps-rails/60A1603A0A0.aspx
or this: http://motorhaven.autoanything.com/bed-caps-rails/60A1604A0A0.aspx
Old 01-18-2008, 03:19 PM
Thanks guys. Good comments and ideas.
Has anyone actually used these though?
Old 01-18-2008, 04:12 PM
RickF350's Avatar
RickF350 RickF350 is offline
RickF350 is gaining momentum as a positive member of FTE.
Yeah I've got them on my truck. Good fit, strong and easy to install. I took a rough "ID" measurment of the ring pulled out and came up with 7/8" wide x 1 1/8" high. However, because for the recess in the base you might be limited to about 3/4" high ID. The steel that makes the ring is about 5/16" thick. If you want to take a look at one, Walmart stocks them.
I have not had them freeze up with ice, but I can see how it could happen.
Old 01-18-2008, 04:26 PM
Beerstalker's Avatar
Beerstalker Beerstalker is offline
Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.
I bought them for my dad a few years back and he uses them all the time. They can get stuck a bit, but a screwdriver will usually pull them out. We always just use ratchet straps or tie down straps, so we don't have to worry about getting multiple wraps of rope through them.
Old 01-18-2008, 07:32 PM
DCSpecial's Avatar
DCSpecial DCSpecial is offline
DCSpecial has a great reputation on FTE.DCSpecial has a great reputation on FTE.DCSpecial has a great reputation on FTE.DCSpecial has a great reputation on FTE.
I have them, very nice.
As mentioned they do sometimes get stuck if you don't use them for a while but you can easily pop them up with a knife, screwdriver, pliers, etc...
Old 01-19-2008, 01:28 AM
thanks for the info.
Old 01-19-2008, 01:37 AM
greythorn3's Avatar
greythorn3 greythorn3 is offline
greythorn3 has a good reputation on FTE.greythorn3 has a good reputation on FTE.greythorn3 has a good reputation on FTE.
they suck if you live near snow
filters for wvo or wmo davidwjacob Bio-diesel, Propane & Alternative Diesel Engine Fuels 5 10-24-2014 09:02 PM
a question for Dave S and anyone else that has an idea tjc transport Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 01-18-2011 07:28 AM
5TH wheel to gooseneck conversion dave98 Fifth Wheel & Gooseneck RV Towing 10 04-01-2005 12:31 PM
77 High Boy Front Axle Swap az4x4bronc Clutch, Transmission, Differential, Axle & Transfer Case 2 03-13-2004 09:20 PM
VIN # and Tracking Dave 1999 to 2016 Super Duty 3 06-13-1999 09:14 AM
Tags
bull, ford, install, keeper, ring, rings, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
