Are the EGR & ICP easy repairs?
Old 01-18-2008, 07:56 AM
eric777's Avatar
eric777
eric777 is offline
It seems I have seen a lot of the early 6.0's with issues with the ICP and the EGR. Is the ICP like the CPs on a 7.3 and what is the EGR? And if these things crap out, can they be replaced at the house and are they costly?
Thanks
Old 01-18-2008, 11:29 AM
BowTieHatr's Avatar
BowTieHatr
BowTieHatr is offline
egr and icp sensor yes easy fixes. icp problems on the other hand, can be rather bad.
Old 01-18-2008, 11:56 AM
randomhero1172's Avatar
randomhero1172
randomhero1172 is offline
Old 01-18-2008, 12:14 PM
doubledee715's Avatar
doubledee715
doubledee715 is offline
could you define bad? bad as in hard to replace or bad as in bad for the truck. I'm getting mine replaced monday but just looking for more info on the issue. thanks.
Old 01-18-2008, 06:47 PM
3000 FPS's Avatar
3000 FPS
3000 FPS is offline
Thanks
EGR stands for exhaust gas recirculation and it is a valve that sits on top of the engine just in front of the fuel filter that allows exhaust to recirculate back into the intake of the engine. It is not a real cheap item from ford if you have to buy one. The ICP is a pain to get to and it is located at the back of the engine behind the turbo between the Y pipe that is for early build only.
Byrddog
03-18-2012 04:23 PM
iduger
11-04-2010 10:53 AM
embry1123
03-22-2010 09:13 PM
Chistoso
22
09-18-2009 10:13 PM
Nahkohe00
32
09-12-2007 04:02 PM
Quick Reply: Are the EGR & ICP easy repairs?
