Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Computer Chips and Tuners
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-18-2008, 04:09 AM
sfgiantsfan9 is starting off with a positive reputation.
DP Tuner worth the money?
I have a superchip on my 7.3 Powerstroke already but i hear alot of great reviews on the DP tuner. Would the power gains be worth the money to swap out the superchip for the DP? Also, do you only buy the tunes you want? Which of the available tunes do you guys reccommend. I want the most power i can get for street driving but also haul sometimes too. What do you guys reccommend?
__________________
2001 Ford F250 Lariat 7.3 Diesel
6 inch Fabtech Lift
35" Pro Comp X-terrains
17" Moto Metal 951 chrome rims
5" straight pipe exhaust
DP Tuned
3 Kicker CompVR subs, 3 profile 1000m monoblock amps
4 Polk Momo 6 1/2 components, 2 JL Audio 1200 Watt Amps
Pioneer Premier Headunit
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-22-2008, 10:01 PM
Red Monkey's Avatar
Red Monkey is starting off with a positive reputation.
I went from a Superchip to a DP Tuner with the following: 1. Stock, 2. 60hp tow, 3. 80hp econo. You can add as many tunes as you have $$$$ but I figured these three were best for what I wanted.
The DP Tuner is a L O T better than the Superchip tuner IMHO. My truck would throw codes during hard acceleration with the Superchip in tow performance and performance mode. Plus my EGT's were higher than I liked when towing our TT with the superchip. After adding the DP Tuner I get no more code and MUCH better performance plus my EGT's are lower when towing.
If you go with a DP Tuner you won't be dissatisfied. Call Jody at DP and tell him what you want to do with your truck and he will make some suggestions. You can then decide what is right for you.
Good luck,
Hal
__________________
01 F250 7.3 4x4 6637 air filter mod, CCV mod, pyro, EGT & boost guages, 4" turbo back, door molding mod, F5 DP-Tuner.
89 Toyota 4Runner SAS, Marlin Crawler hy-steer, Marlin Crawler Ultimate dual t-case, 5.29 gears, Toyota electric locker front, Detroit locker rear, 4 wheel disk brakes, t-case e-brake, full roll cage, Warn 8274, 22Re 5 speed.
  #3 (permalink)
Old 02-06-2008, 08:05 AM
lawngrease is starting off with a positive reputation.
I can back up what Red Monkey said. I too have the DP with the exact same settings except that I also have "120hp race". Jody is extremely helpful in helping you choose what to get. You can always have tunes added later, and he did not pressure me to buy any more than what I wanted.
  #4 (permalink)
Old 02-06-2008, 09:11 AM
tex25025's Avatar
tex25025 is gaining momentum as a positive member of FTE.tex25025 is gaining momentum as a positive member of FTE.
I don't know much about the dp-tuner as the favored for the 6.0 is the SCT with custom tunes, however, I do believe no matter which tuning platform you use, custom tuning(or custom anything) really seems to deliver the most benefit then the one size fits all type of approach(more times then not).
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
SCT w/Spartan tunes(including FICM tuning)
Fuel Regulated Return
FASS 150/180
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
  #5 (permalink)
Old 02-06-2008, 04:22 PM
officer131 is starting off with a positive reputation.
I just rescently purchased an 02 X and started to buy performance parts. I am looking into the DP also with all the hype on the sites here. Seems just to simple to intall and work with. It doesn't look to big on the dash.
Officer131
  #6 (permalink)
Old 02-06-2008, 08:28 PM
Quote:
Officer131
It is amazingly easy to instal. It is not just hype it really is great, and Jody can help you through your decisions. They have great customer support.
  #7 (permalink)
Old 02-11-2008, 12:23 AM
fnx4wheeler is starting off with a positive reputation.
Yes, it's way worth it. Put in my Dp two weeks ago and love it. I didn't buy the Over Boost accessory and haven't had any problems. I got 40,60,80tow, 80 economy and 120 race. Used to see 12-12.7 mpg around town/highway. Got back from a 1500 mile (highway) trip and saw 16.3 mpg. No B.S.
  #8 (permalink)
Old 02-11-2008, 11:39 AM
what setting did you get your 16mpg at wheeler
__________________
AL,
2002 Excursion 7.3 diesel. 4" SS #409 MBRP exhaust. AFE stage 2 w/ pro guard air intake. Autometer Cobalt series gauges w/LED Boost, Pyro, Trans, And Fuel Pressure.
  #9 (permalink)
Old 02-12-2008, 07:26 PM
I had the 80 economy setting on the whole way. Didn't hot dog but I did floor it a half dozen times or so passing on the highway. Drove between 67-75mph (2000-2300rpm).
  #10 (permalink)
Old 03-27-2008, 09:19 AM
kvom is starting off with a positive reputation.
I also have the DP-Tuner with Stock/60t/80e. Drive with the 80e setting 90% of the time. It makes my truck (F350 CC LB) drive like a car. I get 16-17mpg interstate unloaded. In reality the economy gains from the 80e are fairly small, but it's nice to be able to get up to speed from a full stop fairly quickly.
Towing my Jeep+trailer at about 6500lbs with the 40t I get 13-14 mpg depending on the terrain.
  #11 (permalink)
Old 03-29-2008, 06:17 PM
4wydnr is starting off with a positive reputation.
I started with a super chip then moveed to adp tuner a year ago and haven't lookde back. However, last night I pulled my dp to run a superchips programmer that a friend of mine was testing out. My opinion remains unchanged, the superchip does not compare on any level. The performance setting has less go than my 80 economy setting and the 120 blows it out of the water.
As far as a setting for daily driving and towing my truck is on the 80 e seeting about 85% of the time. Even when towing 14,000 lbs, if you don't drive like a mad man the egts aren't a problem.
  #12 (permalink)
Old 04-03-2008, 10:03 PM
big poppa pump's Avatar
Where,s My Shirt!!!!!!!!!
big poppa pump has a great reputation on FTE.big poppa pump has a great reputation on FTE.big poppa pump has a great reputation on FTE.big poppa pump has a great reputation on FTE.big poppa pump has a great reputation on FTE.big poppa pump has a great reputation on FTE.
As soon as i get a couple other mods like gauges and vb for trans im ditching my superchips for a dp, definitly.
__________________
Mike 2003 f-250 XLT CC 7.3 SB, auto, 4x4 373,s S-B air intake w snorkel,DP Tuner-NS,Stock,60T,80E,120R,140A, WW, CCV mod, SC Codereader, Isspros 3 pillar, foil del, MBRP 4 in duals, 285 Yoko,s A-T, Bilsteins, 2in shackle kit (Thanks Zack7.3), Zdad, CrimeStopper Alarm w remote start, Cobra 29 cb dual firesticks. PAA MEMBER 26#
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
