Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-17-2008, 11:21 PM
imfinethanx is starting off with a positive reputation.
Question oil pressure intermittently drops to nothing
Then right back up again. It doesn't go low, it goes all the way down to nothing. When I rev the engine a bit, it comes right back. I checked the oil, it's fine. If it's actual oil pressure, wouldn't the needle fluctuate to low and then maybe nothing? It's all or nothing here. Let me know.
J
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-18-2008, 01:02 AM
LxMan1's Avatar
LxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to behold
Well, it may be as simple a bad sending unit.
The gauge is a dummy gauge. If you have over about 6psi, it will read just above 1/2 way. I would change the sending unit and if it still does it, then definitely check the pressure with a real gauge.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
