Fordamatic trans problem
56 has an automatic Fordamatic transmission with a automatic columb shifter.
On the side of the trans is a linkage that is connected to the columb shift.
Around this linkage that conects to the shaft that goes into the side of the tranny there is a constant fluid leak.
Does anyone know if the seal is on the outside or do you have to pull the pain to get at the seal?
This tranny has an oil cooler line that goes to the radiator so not sure what year it is.
Any giudance is much appreciated very excited to work on this but the tranny fluid leak is a bummer.
Mick
Mick
Received 1,344 Likes
on
Hi Brian,
I wish some experience would chim in here on this one...
I wanted to know if you have to drop the pan to get at the linkage seal and how the linkage is removed. I have a friend who also has the exact same leak!
So hope any light or suggestions would be made on this for this will be my first priority to fix.
I don't know if there is one available for the Fordomatic or not but there are special shift shaft seal removal tools available for GM and Chrysler transmissions that allow you to remove the seal and install a new one without having to drop the pan.
What does the shift linkage look like at the trans? will it come off the shaft just leaving a bare shaft? if so then you could probably drive a screw into the shaft seal and pull it that way and be able to install the new one.
Good luck with it
Bobby
Good luck with it
Bobby
Do you need a special tool to take the linkage shaft out from the inside?
Has anyone got a manual that they can check to see?
I agree this is a common pain in the *** problem..so someone has the finer detail on how to replace the seal.
The tranny seems to shift fine and I wish I could do this myself on a budget.
All inputs and suggestions are welcome..please chim in!
Thanks!!
Thanks!!
Okay, got a few more details. The '56 was air cooled, in '58 they went to a cooler. The '56 has a ball and spring on the rooster comb(it's that part on the shift linkage inside the trans. that sorta looks like a rooster's comb), this setup is a real pain to put back together while in the truck. The '58 has a bullet and spring that is a little easier. You may have to remove or at least move over the valve body to get the manuel lever out. The valve has a couple of lines to it that you have to careful with and also you have be careful not to knock off the second gear band strut. There is a seal on the shaft of the manuel lever and a o-ring on the kick-down shaft lever. No special tools are required. This is not a job for the faint of heart.
jackietreehorn
15
12-09-2016 07:52 PM
cprivette
11-12-2016 08:53 AM
Dustin_86
01-05-2004 06:21 PM
1956, 1966, 292, 56, 59, change, ford, fordamatic, fordomatic, removal, seal, shaft, shift, trans, transmission
