Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > The 2009 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
The 2009 F150 Discuss the new 2009 Ford F150
Is F-150 Still King?
LinkBack Thread Tools
  #76 (permalink)
Old 01-25-2008, 07:45 PM
MM1281 is starting off with a positive reputation.
fonefiddy, around here the people with half ton trucks usually haul a couple of sacks full of groceries. A handful tow boats under 5K lbs and a small percentage actually use them for work purposes. Half of those peeps could get by on a smaller truck but they just dont have enough room in the bed.
I understand your point and everything is a compromise.
  #77 (permalink)
Old 01-25-2008, 07:52 PM
fonefiddy is starting off with a positive reputation.
I need a full size trucks, also. I usually carry 12-1500 lbs in/on my trucks and occasionally tow equipment. I'm not stupid enough to do it all with a 1/2 ton. My Diesels get 15-18 MPG Depending on load/terrain.
But I do need a 4X4 1/2 ton to haul smaller equipment, and supplies. There's no way it should get worse milage than my loaded diesels.
__________________
93 F One Fiddy- 5.0/AOD/3.55 230K OEM
93 F Two Fiddy Scab- 7.3/ZF5/4.10/Sidewinder II,94 Turbo pump,G Inj's, Velvet Ride, Turbo Bumper, Alcoa's
85 F Two Fiddy-6.9/C6/3.54/ Holley Red, Racor, Soup Bowl,AutoJet 3",Ride Rite Rear
  #78 (permalink)
Old 01-26-2008, 03:56 PM
dwrestle is starting off with a positive reputation.
I think they should make a light half ton truck, maybe call it....The F-100 yeah thats cool. It should have all kinds of weight reduction surgery, possibly even be a totally different platform(costly I know), give it a stout 6 cylinder a small V8 and a diesel engine as an option. It shouldn't be rated to tow more than 8000 lbs. It should have the ability to be just as blinged out as the F-150 currently is. In the meantime the F-150 can replace a more traditional 3/4 ton(as opposed to super ginormous big huge ass goofy monster Super Duty) truck by making it heavier and giving it a bigger engine, and bump the towing up to like 13,000 pounds.
  #79 (permalink)
Old 01-26-2008, 04:28 PM
Umm. Ford allready has the F250/F350????
They just need to get the pork off the F150! Fark a bunch of 10K trailer capacity. That's what the 250+ are for!
__________________
  #80 (permalink)
Old 01-26-2008, 08:31 PM
LxMan1's Avatar
LxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to behold
Quote:
Originally Posted by RoyJ
I completely agree; using an F150 for what it's designed for would be ideal indeed. Unfortunately, it's nearly impossible due to our culture.
For some bizzare reason, North Americans think driving a pickup for no reason is "cool". That's why we're the only ones in the world to have "luxry" trucks.
I read something funny in this month's "Men's Health" - when it comes to picking up women, a "pair of jeans and a pickup" was rated 2nd place out of many other options, including Jags, Ferraris, Caddilacs. The only one to beat that combo is "pressed shirt and a BMW".
So, no one's going to give up their pickup truck fashion statement for a while, and the only option left is to make them more fuel efficient when guys try to hit on ladies with their 9000 lbs F450 in the middle of LA.
Well darn, if I would have known that, I would have bought a pickup back in 88 instead of my 5.0 LX Mustang
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #81 (permalink)
Old 01-28-2008, 03:32 PM
Yeah I know Ford has a 250 and 350, but who wants to drive them they are to freaking big to park and drive. I'm saying bump the 150 up to light 3/4 ton status it's already heavy enough, my buddies 98 Chevy 2500 is only like 6500 lbs. Whats the heaviest 1/2 ton Ford like 6200 lbs? They should just make the truck a little heavier and put the V-10 as an option with like a 13,000 lb towing capacity.
  #82 (permalink)
Old 01-28-2008, 03:44 PM
dkf's Avatar
dkf dkf is offline
dkf is gaining momentum as a positive member of FTE.
Quote:
You must suck at driving then. A SD isn't much bigger than an F-150, I can get my SD where I please.
90's Chevy 2500 are weak little trucks. I worked on one at work wiring and mounting a hitch and salt spreader. The frame on my 74' F-100 is thicker than that 93' 2500 was, especially in the back.
I highly doubt you'll fit a 6.8l in an F-150, not without a redesign. The F-150 and SDs are fine the way they are set up, no need to screw around with weight capacities.
  #83 (permalink)
Old 01-28-2008, 04:23 PM
It's true. Park a SD next to a F150, there's not much differance
__________________
  #84 (permalink)
Old 01-29-2008, 09:07 AM
Power Kid is starting off with a positive reputation.
Wink
Quote:
Until you get into the tighter parking garage. Then the difference shows up.
  #85 (permalink)
Old 01-29-2008, 11:17 AM
dkf's Avatar
dkf dkf is offline
Quote:
Trucks don't belong in parking garages anyway.
Of course I don't live in the city.
  #86 (permalink)
Old 01-29-2008, 03:56 PM
Like I said, dimension wise, there's not much differance.
The F150 SCab 6.5 is listed @229.8" X 78.9"
The F250 SCab 6.75 is listed @231.8" X 79"
So the F250 is 2" longer and .10" wider.
__________________
  #87 (permalink)
Old 01-29-2008, 04:32 PM
dkf's Avatar
dkf dkf is offline
I believe you sit a tad higher in the SD than you do the F-150s, thats why people think they are bigger and tougher to maneuver.
The turning raduis is larger on the SDs though due to the solid front axle. I love driving my SD, I'm glad I bought it over the F-150 I test drove.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
