Usually you want to ask the questions before you buy the parts.
What motor does your truck have in it?
If I would have known beforehand that some ZFs had speedometer drives I certainly would have asked. This site is a wealth of information, that what makes it great.
I'm guessing the answer is "no", but does anyone know a way to get around the electronic speed sender in the newer ZF's? I'm interested in a small block one, which already constrains the supply without having to find those particular years.
The only vehicle I worked on that had an electronic speedo, had a sending unit that plugged into the same hole the cable would have. Is the design of your ZF different in that the hole has changed? I would have thought you could just remove the electric speed sender and plug in a cable.
That's the $64 question - haven't picked one up yet so I don't know. I originally assumed it would just be an electronic unit plugged into the hole where the cable is, but then I got to thinking about how they might have to put an electronic pulse reader in a different location than a gear-driven cable.
The 92-up trucks had the VSS mounted on the rear end housing, so there would not be anything in the transmission. I do not know if there is still a provision for a cable and gear at the back of the transmission or not. I think the safe assumption is no. An 88-91 transmission will have one for sure (as long as it's a 2WD transmission).
I am wanting to do the same thing in my truck. 77model with 351M. Can't get over how much overdrive units are. What did you pay for this? I have a 4spd and wondering if the clutch that is in there I can keep. Previous owner put it and I like it alot.
