Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-17-2008, 02:42 PM
JCastellaw is starting off with a positive reputation.
Oil smells like gas!
My Oil has a gas smell. Is that a problem???
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-17-2008, 10:14 PM
Boba Fett is starting off with a positive reputation.
Stop running the truck and change the oil immediately!
If your carb is running too rich you are not only washing you cylinders with gas and ruining you rings/bores you also run the risk of spinning a bearing with oil that is thinned by gasoline.
How if this thring running anyway? If you have a lot of smoke......
  #3 (permalink)
Old 01-17-2008, 10:26 PM
four4x4fords is starting off with a positive reputation.
Fuel pump diaphram can go bad and allow gas into the oil too....
Gotta park it until you can figure it out
__________________
01' F-350 4X4 SB CC V-10 Driver
76' F-250 4X4 428 Cruiser
68' Bronco Crawler
05' Explorer Wife's Driver
58 Fairlane 500 In progress
53 CJ3B off brand orphan
Reno, Nevada
  #4 (permalink)
Old 01-18-2008, 10:59 AM
It's blowing some sut out the exhaust! New Carb floods.
  #5 (permalink)
Old 02-02-2008, 09:10 PM
TomThrall is starting off with a positive reputation.
Friend, don't run it with a flooding carb, or a carb that mathematically too large for the cubic inches.
Wayyyy back in 1978 no one told me these things, and I put a Holley double pumper 1100 on a 390. It lasted nearly 500 miles before I washed the cylinders and ruined a new overhaul.
  #6 (permalink)
Old 06-11-2008, 11:19 AM
Could it be fouled plugs from running bad gas??? It's not smoking now that I cleaned the fuel tanks out but still has the gas smell coming out the tail pipes!
It runs great now, but the new carb is leaking on the passenger side behind the electric choke!
  #7 (permalink)
Old 06-11-2008, 12:20 PM
gfw1985 is starting off with a positive reputation.
Carb is new-return it. I got a new, bad one a couple months ago. Throttle shafts were leaking right out of the box.
  #8 (permalink)
Old 06-14-2008, 05:13 PM
RCrawler's Avatar
RCrawler is gaining momentum as a positive member of FTE.
If you are getting a gas smell from the exhaust, you may need to adjust your carb or do an ignition tune up. Assuming that your engine is in good shape. I have a 400 apart right now that started out as a small fuel pump leak into the oil pan and turned into an overhaul when the fuel washed any lube from the cylinder walls and wasted the rings.
Jason
__________________
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
'79 F150 4wd lwb 400, 435, 205
"You can take the boy out of the trailer park, but you can't take the trailer park out of the boy."
  #9 (permalink)
Old 06-15-2008, 07:41 PM
rebuilt engine new fuel pump new 600 holley!
  #10 (permalink)
Old 06-15-2008, 07:42 PM
new mallory hei ignition!
  #11 (permalink)
Old 06-15-2008, 07:43 PM
would a fouled plug or plugs do it?????
  #12 (permalink)
Old 06-16-2008, 09:06 AM
Also, had an older 4180 carb on it till I installed a new 600.
I also installed a new fuel pump and that may be the culprit. Is there a place to send my oil and find out how much gas is in it??????
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
