Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Supercharger, Turbocharger, Nitrous Oxide and Water/Methanol Injection
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-17-2008, 10:54 AM
mrpositraction is gaining momentum as a positive member of FTE.
Roush on order
Found a deal and just couldn't pass it up. Got it for $4333 shipped. This comes with the supplemental kit for my 2007 F150. Inter-cooled and everything, it is brand new. Should be shipping today so I should have it some time next week. Won't be installing it right away as I want to do a couple other things and pre-assemble before I start the major assembly. Like getting the fan shroud cut, power steering moved, IC mounted, possibly in a different location that the install instructions mention, and the drive pulley for the S/C installed. I would like to get it the point that install will take a lot less time. I also have some thoughts on getting the PCM re-flashed at Roush and then pulling the tune out of it until I am ready to install, that way I am ready to do everything when the time comes, and my down time is minimal. I need to contact them to make sure I can do this first. I will post pics as I go along. If anyone has any tips I am all ears, can't wait to finally run some boost.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-17-2008, 01:27 PM
FTE Ken's Avatar
Administrator
FTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputation
That is a good deal!
Tips:
1. Swap in a larger lower pulley (same pulley a Lightning uses). Only go one size larger. You don't want to run more than 8lbs on a stock 3v 5.4L. Not only is it going to give you more boost, but its a much lighter than the Roush pulley.
2. Call Mike Troyer after the install. With the pulley and his tunes you'll run about 60-75 HP over what Roush gives you, plus throttle response is better.
3. Go ahead and get gauges now.
4. If you're planning electric fan conversion, do it before you install the supercharger. You'll have a lot more room when you're done and it should help make the Roushcharger install easier.
5. Gap the HT0 plugs down to 35-40. Get an extra set in advance... (I can tell you where to get a set for $79). These aren't supposed to be gappable, but there is a very easy way to do it. Let me know if you need help with this.
__________________
Ken Payne
Gone Fishing...
LACK OF PLANNING ON YOUR PART DOES NOT CONSTITUTE AN EMERGENCY ON MY PART.
2006 Roush F150 Project: Roush Supercharger, Troyer & My Tuning, 9lb pulley, Level 10 Trans, E-Fans, Oil Separator, Brandmotion GPS, BlueConnect Hands-Free Phone & iPod Direct Connect, Black Headlights & Taillights, Retrax Retractable Tonneau & more.
2004 F250 King Ranch Crewcab 4x4 6.0L PSD project: DP-Tuner Tuning and MBRP Stainless Dual Exhaust.
2000 Ranger Supercab XLT 3.0 V6 project: Bright Box, Mac Intake, Tonneau, my tuning.
RIP: 1967 & 1975 F100, looking for a 66 F100
  #3 (permalink)
Old 01-17-2008, 01:33 PM
Great advice on the lower, I have a lightning buddy I was thinking of hitting him up for the inter-cooler and I will see if he has the lower pulley as well. I already have gauges installed. I am hoping to use the Roush tune to start and then work on with HP. If that doesn't work I will give Mike a call. Please let me know where I can get the plugs for that price. What plugs come with the kit then?
  #4 (permalink)
Old 01-17-2008, 02:01 PM
FTE Ken's Avatar
Administrator
HT0 plugs come with the kit along with EVERYTHING you need... but you will be going through plugs if you like hitting the throttle a lot.
If you need a pulley, I have several, new in the box and I'd let one go very cheap - they aren't doing me any good sitting on the shelf. We'd need to handle that via PM or email... no sales allowed in the forums.
There are a lot of things that need to be done to the Roush tune that most shade-trees (including those with tuning experience) aren't going to be able to accomplish. For instance, Roush's tune has a tendacy to peg the voltage on the fuel pump. There are proper ways to decrease the voltage while increasing the available fuel but that's beyond the scope of a forum post. A/F ratios don't need to be touched - Roush has those dead on.
IMRC, timing, lots of things on the tranny and some cam control changes need to be made, plus a variety of other things to get optimal power. I've done a lot of tuning over the years but Troyer has installed and tuned more Roushchargers than anyone in the country. I'm going up there to hang with him (nice guy... funny how I've ended up being friends with someone who was once my competition) and do some dyno tuning. We're both fairly certain we can squeeze some more out of it, getting us up to the 410 RWHP range (stock was about 210-220 depending on the weather, and a standard Roush install around 328 RWHP). I've squeeze quite a bit out of it with a wide band and data logging, but nothing beats dyno time.
What would you be using to tune it? The SCT Pro Racer package? If so, be aware they do not turn all access to all the parameters you need for optimal tunes. Even most dealers don't have access to the "calibrator" level stuff.
Jusnes Modified, an FTE sponsor, has the plugs for $79/set -- about the best price you'll find anywhere.
__________________
Ken Payne
Gone Fishing...
  #5 (permalink)
Old 01-17-2008, 02:11 PM
I will be sending you an email.
I am using HP tuners to currently tune my truck and was planning on using that to tweak the Roush tune. Thanks for the plug info, I will be needing them in the near future.
  #6 (permalink)
Old 01-17-2008, 10:58 PM
If anyone is interested I see they have another for the same price.
eBay link here
  #7 (permalink)
Old 01-24-2008, 01:13 PM
w00t w00t
UPS man came today, and look what he brought me.
Let the fun begin!
  #8 (permalink)
Old 01-24-2008, 09:52 PM
FTE Herman's Avatar
FTE Herman has a great reputation on FTE.FTE Herman has a great reputation on FTE.FTE Herman has a great reputation on FTE.FTE Herman has a great reputation on FTE.FTE Herman has a great reputation on FTE.
We are all so very happy for you, you won't be disappointed.
__________________
2000 Boss Gator 4x4 Kenne Bell
Max HP: Classified
Max Torque: Classified
0-60: Classified
Best 60': Classified
Best 1/4: Classified
Do it right, do it once (perhaps twice if you try to run more than 14psi on stock rods, or if you don't read the instructions properly).
  #9 (permalink)
Old 01-24-2008, 11:34 PM
Blurry94's Avatar
Blurry94 has a good reputation on FTE.Blurry94 has a good reputation on FTE.Blurry94 has a good reputation on FTE.
Now that's BAD AZZ!!!
__________________
Matt C.
94 Lightning, blown/intercooled stock longblock, 1.76 60' 7.94 @ 90mph (1/8 mile)
01 F-150 4.6 2wd RC, K&N drop in, shorty headers, Flowmaster w/duals
  #10 (permalink)
Old 01-25-2008, 07:09 AM
FTE Ken's Avatar
Administrator
Soon you'll be sporting a permanent grin!
__________________
Ken Payne
Gone Fishing...
  #11 (permalink)
Old 01-25-2008, 07:51 AM
Thank you, I was tinkering around with it last night. I will start cutting the fan shroud and what not this weekend. But I don't plan on doing the actual install for a month or so.
  #12 (permalink)
Old 01-25-2008, 08:03 AM
FTE Ken's Avatar
Administrator
I picked up the pulleys from the storage last night. I'll get back with you, will go through them to let you know the sizes I have.
__________________
Ken Payne
Gone Fishing...
  #13 (permalink)
Old 01-25-2008, 08:07 AM
Quote:
Lol, just sent you an email (before I read this).
  #14 (permalink)
Old 02-18-2008, 02:43 PM
Quote:
Well, I have waited as long as I could. I am installed the S/C on the 1st of March. The timing is perfect becuase I will be out of town for work the entire 1st week of March, this will allow the PCM plenty of time to get to Roush and back to me before I get home. I will begin the install Saturday, but have the majority of it done already. The inter cooler radiator, pump, reservoir, hoses, and wiring are already installed. The lower pulley and fan shim is already installed. The fan shroud is cut, the power steering pump is relocated, and all the gauges (including wide band, trans temp, and boost) are installed and working. The plugs are gapped, all assembly I can do outside the motor is done, and I have the oil, anti-sieze, special spark plug socket, anti-freeze, and filter already purchased. This weekend I will need to get the carb cleaner Ford recommends for the plug removal and a fuel filter. I am switching to Amsoil 5w20 fully synthetic and NAPA Gold filter. I also need to pick up two bottles of water wetter, one for the engine, and one for the intercooler. I have been thinking of going with a lower temp thermostat, what do you guy think of that. Since I will be working right next to it, I might as well swap it out. Also, the heat get plenty hot in my truck, I wouldn't mind if it was a little cooler.
Thanks,
Greg
  #15 (permalink)
Old 02-18-2008, 04:09 PM
FTE Ken's Avatar
Administrator
For the intercooler only use a couple of ounces, max, of the water additive. Too much will cause it to foam and raise intake temps. How bad will it foam...? It will practically look like shaving cream. Don't ask me how I know!
Personally, I run Royal Purple and Mobil 1 in my truck (all fluids swapped out) and use Mobil 1 filters. The K&N filter is the same as the Mobil 1 filter, but has a nut on the end for easier removal (not worth the extra money for the nut, IMHO). NAPA Gold are great filters also. While you are at it, change the fuel filter and the O2 sensors. Change the fuel filter and O2 sensors every 25K miles and oil intervals at 3K max. I also send my oil in for analysis every other change.
Personally I wouldn't switch the thermostat.
__________________
Ken Payne
Gone Fishing...
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
