Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > The 2009 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
The 2009 F150 Discuss the new 2009 Ford F150
Is F-150 Still King?
LinkBack Thread Tools
  #46 (permalink)
Old 01-21-2008, 08:37 AM
BLK94F150 has a very good reputation on FTE.BLK94F150 has a very good reputation on FTE.BLK94F150 has a very good reputation on FTE.
I would just like to see some more stuff as options. Obviously with more moving parts, there are bound to be more problems. Oh and even though it's not designed to ride better than springs, the air dump system we have on the 450s rides better than the springs on the 350.
Has anyone ever seen or used the Telma electronic brake? Awesome system and really helps in the whoa dept.
Mike
__________________
2000 F150 5.4 4R70W 4x4 Supercab 3.55 gears
  #47 (permalink)
Old 01-21-2008, 09:53 AM
LxMan1's Avatar
LxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to behold
Yep, I just had to replace the air bags on my 96 Windstar that has a lowered floor for a wheel chair. They are aftermarket (air lift) bags installed by the conversion company. They lasted 11 years before the elements caused the rubber to deteriorate enough to start leaking air. My next lowered floor van will have springs!!!
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #48 (permalink)
Old 01-21-2008, 10:01 AM
osbornk is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Jonas1022
Right! I had a Pontiac 6000 STE in 1984. It was an 83 model. Air pump, powered by a little electric motor, and it filled a resevoir like you say. When the car was heavily ladden with five fat butts, it couldn't overcome the load. The back end still sagged. So in my thoughts it would have to be a pto from the engine with a more serious pump than what that STE had. BTW, it's air bags went out twice in the second year I owned it, and not from overloads. It was just one person in the car. So, adios Pontiac. Personal experience with air ride suspensions leads me to believe that they are more problematic than what they are worth. I like the ride, hate the non-reliability factor.
You can't compare anything with GM products of the mid 80s. They couldn't get anything right during that period of time. My Town Car is 10 years old with 115,000 miles and the bags and pump have given me no problems. I was concerned about the cost before I bought the car several years ago and aftermarket air bags were around $70 each and it doesn't take long to replace them. The little electric air pump has never had a problem with pumping up the bags. You just have to remember to turn off the suspension before you jack it up or it sits on the ground when you lower it and it takes it a while to pump back up.
__________________
2004 XLT Regular Cab, Short Bed, 4X4 with 5.4 and 3.73.
  #49 (permalink)
Old 01-22-2008, 02:59 AM
bigwobbely is starting off with a positive reputation.
sounds like most of you want the old crappy i-beams back....
__________________
CAN'T TAKE IT WITH YOU WHEN YOUR GONE,
BUT I WANT ENOUGH TO GET THERE ON!!!!!
  #50 (permalink)
Old 01-22-2008, 08:33 AM
Quote:
WTF? Did you even look at the suspension.
The more I read about this truck, the more I like it. They even mention a Hybrid model. It's about time.
Mike
__________________
  #51 (permalink)
Old 01-22-2008, 11:13 AM
LxMan1's Avatar
What do I-beams have to do with coil springs on the rear of a truck besides nothing??
__________________
88 5.0 LX Mustang
63 F100 351W/C6
  #52 (permalink)
Old 01-22-2008, 01:23 PM
Jonas1022's Avatar
Jonas1022 is starting off with a positive reputation.
Quote:
Everything. To someone with analretinaloculitis.
Hey LxMan- Your Windstar. Did your conversion changeout the front springs to airbags? And if so, did it eliminate the ballbearing saddle at the top where the springs mount? I ask because my brother had a couple Windstars and that was a problematic area. He had to replace that "saddle" twice in each minivan.
  #53 (permalink)
Old 01-22-2008, 01:25 PM
V8EXPLR is gaining momentum as a positive member of FTE.
Depending on how you will use the truck, the coils could be a good way to go. Personally, I'll stick with the leafs.
Oh, and I think the Ram interior still looks like cheap plastic and vinyl. Even if they tried to copy cat.
__________________
Justin
2006 Ford F-150 SuperCrew XLT Chrome Edition
5.4L Flex-Fuel, 3.73LS, 18" Stock Rims, 18" BFG Rugged Trail T/A's, Trailer Tow Pkg
Sun/Moonroof, Fog Lamps, Ford Bedliner
Lund Headlight & Taillight Covers, Lund VentVisors
  #54 (permalink)
Old 01-22-2008, 01:45 PM
blkbrd36 is starting off with a positive reputation.
I have no problems with an air-ride type system, just as I have no problems with the idea of using coil springs in the rear..... so long as it works! I have no doubt that coil springs in the rear, so long it's done right, would easily handle the capabilities and usage of 100# of half ton owners out there(at least the owners who expect 1/2 ton capabilities out of their 1/2 ton truck). I have never owned a truck with coils over the rear axle, It does sound very different to me, but it's also exciting that someone out there is trying something different. Maybe Dodge will take the cake from Chevy on the "car like ride"(i've never cared for Chevy anyways, or the car like ride) I do like my leaf springs, but leaf with an air assist is the way I would go. As for all air...Didn't the Navigator come with air ride for a short time? It would jack it up two inches when put in 4wd and lower it down at high speeds....I know I was excited to hear about that too(definetly a great cool factor) Sorry For the long Post.
- Adam
Why argue about a Dodge anyways? I know I don't care if a Dodge succeeds or fails. Blue Oval ALL THE WAY!!!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
