Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > The 2009 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
The 2009 F150 Discuss the new 2009 Ford F150
Is F-150 Still King?
LinkBack Thread Tools
  #31 (permalink)
Old 01-20-2008, 01:38 PM
David85 is gaining momentum as a positive member of FTE.
The big advantage of coil multi-link over old fashioned leaf spring is better handling. Braking is more precise, and power to the road is more instant, instead of having the leaf springs flex slightly before transferring the force to the road. cornering is also better, because as massive as leaf springs can be, they still have some lateral give, and that can contribute to lost traction in more aggressive driving. As for lifting problems, ever see 24" lifts that have suspension swing arms that reach to the center of the truck?
This is merely a sports car trapped in a trucks body, chances are it will give the F150 a run for its money. But I still don't like the center shifter.
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
  #32 (permalink)
Old 01-20-2008, 02:52 PM
BLK94F150 has a very good reputation on FTE.BLK94F150 has a very good reputation on FTE.BLK94F150 has a very good reputation on FTE.
Ditch the leafs and coils. Go airbags. You would never have squat issues and when you open the tailgate, it could dump the bags and make loading/unloading much easier.
Mike
__________________
2000 F150 5.4 4R70W 4x4 Supercab 3.55 gears
  #33 (permalink)
Old 01-20-2008, 04:44 PM
jpeters1 is starting off with a positive reputation.
There was an episode on "trucks" on spike tv where they switched a suburbans coils for air bags with an aftermarket kit. Lower or raise the truck at the touch of a button.
Quote:
Mike
  #34 (permalink)
Old 01-20-2008, 05:04 PM
Air bags are what they SHOULD be using. Most HD hauling and dump trucks use them (some even have the cab partially on air). Way better handling, and the possibility of variable ride height; more ground clearance when off road, and run lower to the ground when on the freeway for better MPGs (and cornering). Smoother ride even when empty too, load responsive pressure, its all been done, much better than steel springs could ever be, coil or leaf.
__________________
  #35 (permalink)
Old 01-20-2008, 05:20 PM
LxMan1's Avatar
LxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to behold
Ever rode in a Mark VII or mark VIII or even a Continental? They ride on air bags, but ain't the best handling cars in the world. Ride smooth though. And The air bags fail after about 10 years and are not cheap to replace. Springs usually last forever.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #36 (permalink)
Old 01-20-2008, 06:37 PM
Jonas1022's Avatar
Jonas1022 is starting off with a positive reputation.
Quote:
I'm not too sure that they last ten years either. Smoother ride!
  #37 (permalink)
Old 01-20-2008, 06:38 PM
Jonas1022's Avatar
Quote:
Doesn't an engine have to run a pump to keep those up? Couldn't that be counter indicated for economy? Just a thought.
  #38 (permalink)
Old 01-20-2008, 06:42 PM
Jonas1022's Avatar
Swing arms on my F-150 aren't bad. Very reliable and I know what I'm getting. It won't corner like a sports car, and well it's all tall so it isn't going to corner like a sports car anyway. Lateral movement, maybe, but not much. Probably more play in the multilink for coils. Need a panhard to keep it striaght. Then again, it isn't a sports car. It's a high and getting higher (with every new model change) center of gravity.
  #39 (permalink)
Old 01-20-2008, 06:45 PM
Quote:
Nope. There is a pump, but once the bags are filled it shuts off. Think of air bags like adjustable springs, except they don't rust. There is also a small air tank on board that is pressurized to a higher value and acts as a reservoir for the system for faster responce time when an increase in height is required.
__________________
  #40 (permalink)
Old 01-20-2008, 06:49 PM
Jonas1022's Avatar
Quote:
Originally Posted by Monsta
We don't need a GD physics lesson on leaf springs for Pete's sake. Who are you trying to impress?? Ever heard of progressive rate coil springs? Guess not...
They themselves will tell you that they were NOT making the Ram to be the best hauler or tow-er. They are making thier truck for the other "half" who don't need such extreme capabilities. Basically: a truck for people who don't necessarily need a truck most of the time. Nuttin' wrong with that. They have a HUGE market of those people.
Coils will be fine for its intended mission. Do you really think the engineers they hire have not asked and been asked the same questions? Do you really think they, who teetering on the brink of unemployment, would not put forth their best effort?
LXman...when was the last time you put 6K in the back of an F150??
A snowplow puts more strain & weight on the front than the tongue weight of the largest allowable bumper-pull trailer that a SD can pull. Now dontchya think the engineers at Ford took that into account?
Obviously I am not impressing you. No matter, you already know all about it. And progressive rate springs are also available as leaf springs...No news there either, is there? Coils are superior riders to leaf springs. I am objecting to the make over of utility vehicles into inferior cars. And cars being made over into something that no one wants. That's the true bottom line of my arguement.
Extreme capabilities? Half tons built in the past twenty years are perfectly capabile of carrying one ton in the bed of the pickup. And giving a good, but not floaty like a limo ride.
  #41 (permalink)
Old 01-20-2008, 06:55 PM
Jonas1022's Avatar
Right! I had a Pontiac 6000 STE in 1984. It was an 83 model. Air pump, powered by a little electric motor, and it filled a resevoir like you say. When the car was heavily ladden with five fat butts, it couldn't overcome the load. The back end still sagged. So in my thoughts it would have to be a pto from the engine with a more serious pump than what that STE had. BTW, it's air bags went out twice in the second year I owned it, and not from overloads. It was just one person in the car. So, adios Pontiac. Personal experience with air ride suspensions leads me to believe that they are more problematic than what they are worth. I like the ride, hate the non-reliability factor.
  #42 (permalink)
Old 01-20-2008, 07:10 PM
LxMan1's Avatar
I usually convert all air ride cars to springs. One air strut is at least $200, can convert to springs all 4 for about $350. No high dollar pump to fail any more and no more bags to leak.
__________________
88 5.0 LX Mustang
63 F100 351W/C6
  #43 (permalink)
Old 01-20-2008, 07:19 PM
Air ride can be problematic, but thats why I mentioned the commercial applications that have become more common in recent years. Highway rigs, dump trucks, and even many of the highway trailers use air bags, but they are designed for long term durability, not a cheap smooth ride like some lighter duty applications. As with any other new idea, it has to be built right, if its not then we end up going back to basics (although simplicity is not always a bad thing).
Annother advantage, is with an in cab gauge, you can actually read how much weight you have on your rig. No doubt that is a big reason why air bags are so popular with many big rigs these days.
__________________
  #44 (permalink)
Old 01-21-2008, 07:17 AM
All the F450 ambulances at work have rear air bag suspension. While the ride is not awesome, it's not meant to be. They are there for dumping the air and lowering the truck so we don't have to lift patients as high to load them into the squad.
It is all powered by a small electric pump that fills a tank and has no problems operating the system. It probably cycles at least 30+ times a day with very few problems. I've only heard of one air bag leaking in our fleet of troublesome 450s.
You guys are comparing new systems to vehicles that are over 20 years old. Newer systems should be able to be abjustable for ride comfort, height for off road or interstate operation, and with big enough air lines, should be able to minimize body roll without swaybars.
Just think how much easier it would be to load heavy crap like a fridge or whatever if when you opened the tailgate, that the truck dropped to the bumpstops.
Mike
__________________
  #45 (permalink)
Old 01-21-2008, 08:23 AM
Jonas1022's Avatar
Wink
Mike
Sounds good. They have been using that air bag suspension, same as your ambulance, on U-haul trucks with the kneel to load and the front suspension of city transit buses with the wheel chair lift for over twenty years. It is a commercial application, and with age it become troublesome as well. Nice thought though. They are trying to save your backs!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
