Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-17-2008, 09:11 AM
SteveBricks's Avatar
SoCal Chapter LDR
SteveBricks has a spectacular reputation.SteveBricks has a spectacular reputation.SteveBricks has a spectacular reputation.SteveBricks has a spectacular reputation.SteveBricks has a spectacular reputation.SteveBricks has a spectacular reputation.SteveBricks has a spectacular reputation.SteveBricks has a spectacular reputation.SteveBricks has a spectacular reputation.SteveBricks has a spectacular reputation.SteveBricks has a spectacular reputation.
E40D Problem
'94 F350 7.5 E40D
30K miles on "new" rebuilt
At highway speed, the trans will occasionally "let go" and "slam" back into gear. This problem is intermittent - sometimes I can drive 40 miles with no problems, sometimes it will happen after 5 miles.
The unit is due for an oil change. Am I correct in thinking this situation goes beyond oil alone?
The oil does not smell burned, and looks pretty good.
Any thoughts or suggestions?
__________________
Steve
06 King Ranch CC 4WD PSD
94 F350XL CC 7.5
SoCal FTE
Join our Chapter *HERE*
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-17-2008, 11:04 AM
Mark Kovalsky's Avatar
Mark Kovalsky has a great reputation on FTE.Mark Kovalsky has a great reputation on FTE.Mark Kovalsky has a great reputation on FTE.Mark Kovalsky has a great reputation on FTE.
The Transmission Range Sensor (TRS) is failing. Replace it.
It's also called the Manual Lever Position Sensor (MLPS) or Nuetral Safety Switch (NSS.)
__________________
Mark
Former Ford automatic transmission engineer, 1988-2007.
  #3 (permalink)
Old 01-17-2008, 12:27 PM
SoCal Chapter LDR
Thank you Mark.
__________________
Steve
94 F350XL CC 7.5
SoCal FTE
  #4 (permalink)
Old 04-26-2008, 07:17 PM
tomm211 is starting off with a positive reputation.
I have a '91 that does the same. We have changed all sensors and it has not fixed the problem. I would like to know if you get it fixed.
  #5 (permalink)
Old 04-27-2008, 11:09 AM
Exactly which sensors did you change?
__________________
Mark
  #6 (permalink)
Old 04-27-2008, 11:49 AM
71dusterdan's Avatar
71dusterdan has a brilliant future71dusterdan has a brilliant future71dusterdan has a brilliant future71dusterdan has a brilliant future71dusterdan has a brilliant future71dusterdan has a brilliant future71dusterdan has a brilliant future71dusterdan has a brilliant future71dusterdan has a brilliant future71dusterdan has a brilliant future71dusterdan has a brilliant future
hey Mark can a chime in with some aod questions. got a 92 g.marquis, reverse and od are out. also nuetral with engine running will continue to pull. turn it off and i can push it back freely. are these problems that will straighten out with a complete rebuild? or do i have potential hard part problems? thank you much. Dan
__________________
one sick puppy
Quote:
Originally Posted by 71Dusterdan
WOO WOO Shake wife at weiner
Quote:
Originally Posted by Adm Gary Roughhead, Chief Of Naval Operations
"I never want to see a Sailor or Marine in a fair fight. I always want them to have the advantage."
Quote:
Originally Posted by DONO
Every day is labor day for me. I got up at 1:00 pm, drove down to IHOP for sausage and eggs, checked my Email and here I am.
__________________
Dono
snl#16
Tims' minions - snatch and grab expert
  #7 (permalink)
Old 04-27-2008, 07:36 PM
Quote:
Your forward clutch has failed. You need to take it apart to see what needs to be replaced.
__________________
Mark
  #8 (permalink)
Old 04-27-2008, 10:03 PM
if their is a sensor on the truck it was changed. I did find an emerecy procedure posted that would allow you to drive if the solenoid pack went out. Tried that and it worked fine. The pack and torque converter is the only thing that has not been changed.
  #9 (permalink)
Old 05-09-2008, 03:57 PM
e40d problems
Here is the whole story. this is a '91 e-350 ambulance. about 8 months ago while going down the high way at about 80 mph it slammed out of over drive and back in once. the more we used it the worse it got. We changed the TPS and the shift sensor on the side of the transmission, still got worse. We changed the rpm and speed sensors, no change. It seems to be very throtle position sensitive un till the trans warms up, then it gets really bad. We were thinking about changing the selinoid pack, we have another '91 next to this one, not sure if that could be the problem and not sure how to change it anyhow.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
