E4OD - Errorcode 1, 23 and 29
Old May 5, 2008 | 04:14 PM
aeomholt's Avatar
aeomholt
Hi, my -92 E350 7.3 E4OD have a flashing od-ligt and I'm getting errorcode 1, 23 and 29. Check engine lamp flashes in this order: 1 (weak/very short), 23, 23, 1, 29 29.
What does these codes mean?
The trans misses gears, hard shifts, can't decide which gear to chose, "hard" downshift while stopping. TPS/FIPL reads 0.98V and goes smothy up to 3.8V and TPS/FIPL are the "bad black one".
Anyone who can list/link to all the different errorcodes which the trans can set? I cant find a list anywhere...
Thanks!
Old May 5, 2008 | 06:16 PM
projectSHO89's Avatar
projectSHO89
"1" is not a fault code, it is a separator between the EO/ER and the continuous memory codes.
23 = a problem with the TPS or the throttle mechanicals
29 = PSOM output signal problem
Does your RABS work correctly? The PSOM uses the rear differential RABS sensor as its input. A bad sensor will screw up the whole shifting strategy and the PCM won't know when to shift properly.
Sounds like other vehicles that have a bad VSS sensor...
Steve
Old May 5, 2008 | 07:05 PM
aeomholt's Avatar
aeomholt
Steve
I do not know if the RABS are working propperly or not but I will have to find a wet slippery place to test it. Since the TPS/FIPL are the old black one I think will change it any way.
Where did you find these codes?
Old May 7, 2008 | 03:18 PM
aeomholt's Avatar
aeomholt
I have just tried another instrument and the transmission shifts like it should.
Then I guess it was the PSOM which was faulty. I forgot to test if the cruisecontrol started working again.
Old May 7, 2008 | 05:13 PM
aeomholt's Avatar
aeomholt
Since I'm in the electronics buisness I took the instrumentcluster apart and checked the PSOM PCB and it was full of bad solderpoints. I'm excited to try it tomorrow!
Old May 9, 2008 | 09:25 AM
projectSHO89
In the factory service manual (PCED).
Steve
