Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-16-2008, 06:09 PM
NoAmmo is starting off with a positive reputation.
2003 6.0 Turbo oil suppy.
Does anyone know how to remove the turbocharger oil supply line where it plugs in to a hex adapter fitting on the engine? It looks like a quick connect fitting.
I have a small oil leak where the supply line plugs into the adapter, I'm hoping I can replace an o-ring.
Thanks in advance.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-17-2008, 07:33 AM
npccpartsman's Avatar
npccpartsman is gaining momentum as a positive member of FTE.npccpartsman is gaining momentum as a positive member of FTE.
I thought it was a one piece line. Maybe the older ones have a snap connect. Check and see if there isn't an upgraded supply line. They're not hard to change--3 bolts about 5 minutes.
__________________
I BLEED RAZORBACK RED
  #3 (permalink)
Old 01-17-2008, 07:52 AM
BowTieHatr has a good reputation on FTE.BowTieHatr has a good reputation on FTE.BowTieHatr has a good reputation on FTE.
there is a disconnect tool that is also used to remove the supply line from the injector rails.
__________________
To whom it may concern;
Ford Senior Master Tech since '05
ASE Master Tech '04
6.0ing since '03.
6.4ing IF they tear up
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
