Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-16-2008, 06:04 PM
rousie13 is starting off with a positive reputation.
Exclamation Can't figure out antifreeze leak.....help!!!
I noticed my antifreeze was low and it was wet around the thermostat housing. I replaced the thermostat, o-ring, and thermostat housing but its still wet between the thermostat housing and the intake manifold. It doesn't appear to be nearly as wet as before, but its still loosing antifreeze. Do you guys have any ideas of what this could be? I used an OEM thermostat housing, o-ring, but I used a thermostat from autozone. The upper hose was replaced right before I bought the truck, but it doesn't appear to be an OEM hose. The hose clamp was also replaced. I torqued the thermostat housing bolts to spec when I put it back together. I can't figure this out. PLEASE HELP!!!!!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-17-2008, 08:08 AM
LxMan1's Avatar
LxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to behold
Welcome to the forum
Sounds like there is a possible crack in the manifold.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #3 (permalink)
Old 01-17-2008, 08:05 PM
Turbokid15's Avatar
Turbokid15 is starting off with a positive reputation.
I see you have a 97 f-250 is that correct. If so ford had a recall on the intakes but I believe the recall has ended so the intake would have to come from your own money.
__________________
Quote:
Originally Posted by Phil150
this thing gets like 28 to 33 mpg dependin on my anger level
07 F-350 CC Dually Stroked
Century bed cover and bed rug
73 F-100 SC SB
302/4 Speed
Mine
  #4 (permalink)
Old 01-17-2008, 10:19 PM
Thanks for the welcome. I talked to the dealer and they said the manifolds commonly cracked on the police cruisers, but not so much on the trucks. I looked in the area and didn't see any cracks in the manifold. I'm wondering if the manifold gasket is shot, but i can't explain how its damp on top by the thermostat housing. After I get done driving the truck, its dry by the thermostat, then when I go to check it later its damp. I guess the only way to really tell is to pressurize the system.
  #5 (permalink)
Old 01-18-2008, 12:58 AM
LxMan1's Avatar
Probably separates when hot an under pressure.
__________________
88 5.0 LX Mustang
63 F100 351W/C6
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
