Seized distributor help
I tried to adjust my timing, but the dist, is stuck! I tried penetrating oil, tapping lightly with a hammer, warmed up motor, cooled motor off, etc etc... I am scared to break the dist housing or vac advance. I can't see any way to wrap an oil filter wrench around it with that advance mechanism there... Anyone encounter this with good results? It is a 460.
My 351C wouldn't come out, so it had to be air-chiseled out in bits. I am hoping not to have to do it again!
Mark
Ford started it; Ford will finish it!
Mark
I got mine unstuck with a crowbar, but hey, I'm dumb. It wasn't budgin', oil wasn't workin', and I couldn't turn it with a wrench, so I wedged a crowbar between the block and the distributor and went to town. I've actually done this on both a '74 and an '89. I recommend this only as a last resort however.
The Law
The Law
After soaking it with penetrating oil, start the engine, get the block hot, then press a big chunk of dry ice on the metal bottom of the distributor frame as close as you can get to the block, but not on the block itself. Keep trying to twist the distributor loose every 30 seconds or so. Keep re-applying the dry ice as needed.
Handle the ice with some tongs or a thick pair of leather welder's gloves.
I've had good luck with this procedure before.
Jeepers, man! My freezer ain't cold enough for dry ice! Do I have to take the truck to the hospital for some? I would have top do the job there, since it is pretty warn outside, and it would all melt...
Sounds like a good idea, but I was hoping for something I could do with tools at hand...
Thanks
Mark
Thanks
Mark
You can get dry ice a lot of places, look in the fone book. Cost ya $2 or $3.
A couple of chunks will keep for many hours in one of those inexpensive white foam coolers. I've kept fish I've caught on dry ice in a cooler for several days.
Throw a few pieces in a glass of water to play Dr Jekyll.
Mwuh-ha-ha-ha-ha!
Mwuh-ha-ha-ha-ha!
Update!
I got back at it today. Soaked her in penetrate again, and nothing. I started the truck, and let it warm for a little, but not hot. By gum, the thing moved in one direction by hand! (forcefully) I got it to come back, then played a bit to get it to turn more freely... Boy, am I glad I got that going! I don't think the timing was out that much... I am pulling 15 inches of mercury vaccuum, and it is in the zone where the gauge says 'late ign timing'. I advanced, but couldn't get a better reading anyway... I think 15 is ok on an older motor, no? Compression is 135 psi on the lowest cylinder, 155 on the highest. (one head reads higher that the other) I am sure 87 percent is a good deviation??? Any comments?
Mark
Mark
trinogt, Glad to hear you got your distributor loosened up without having to destroy it. The 460 my son and I just put in our truck pulled about the same vacuum as you have. When we tore it down to rebuild it, it had two cylinders with broken top compression rings , and all the valve seats were pitted.
parkercouple
12-27-2016 01:46 PM
captanron
06-15-2016 06:14 PM
