Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-16-2008, 10:04 AM
iasrap is starting off with a positive reputation.
Engine Restore?
While we are discussing additives.
Understanding that we have a HUEI in our PSD. What is the side-effect of using Engine restore in our crank case?
-Iasrap
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-16-2008, 11:03 AM
Pocket's Avatar
Pocket has a great reputation on FTE.Pocket has a great reputation on FTE.Pocket has a great reputation on FTE.Pocket has a great reputation on FTE.
Don't do it. Additives in oil can cause foaming issues.
__________________
Curtis
2002 F-250 PSD
Best time: 15.3 @ 86.8 MPH at Bandimere - 9/10/08
  #3 (permalink)
Old 01-16-2008, 11:26 AM
rugermack's Avatar
Hunting season is coming
rugermack is gaining momentum as a positive member of FTE.
Snake oil in a bottle.
__________________
Patrick
2000 F250, Lariat, 7.3, SC, SB, auto, 4" MRBP, 6637w/cover, Hypertech, 6.5 Pro Comp, MX6 shocks, 35" BFG A/T, HPX, CCK, Zoodad, AIH, BD wst act, WW, CCV, IPT OBA, shim'd reg. smoked lights, Rhino'd, ARE shell, 08' diff. Tugger kit, 4 disc TC, hutch/harp, ATS flares, Dynatrac free spin.
next mods- gauges(hopefully soon)
  #4 (permalink)
Old 01-16-2008, 11:49 AM
What is the significance of "foaming issues?" What does it do to the engine?
  #5 (permalink)
Old 01-16-2008, 12:28 PM
Pocket's Avatar
Since HEUI injectors use high oil pressure to fire the injectors and atomize the fuel, foaming prevents the injectors from firing correctly. If foam is in the high pressure oil system, then injectors fire with lower atomization and you have a rough running engine, stalling issues, excessive smoke, etc.
__________________
Curtis
2002 F-250 PSD
  #6 (permalink)
Old 01-16-2008, 07:13 PM
Good to know, does anyone know if the little can of this stuff will cause it for sure?
  #7 (permalink)
Old 01-16-2008, 08:08 PM
jim henderson has a good reputation on FTE.jim henderson has a good reputation on FTE.jim henderson has a good reputation on FTE.
I thought Engine Restore is that snake oil in a bottle that "Fills in all the cracks and pits in metal surfaces". It supposedly uses tiny metal particles that seek out and fillin the cracks.
I have never used it but a bit of thinking might lead to questions such as 1) How does it know what holes and cracks to fill and which ones not to? Like piston ring lands, oiling ports etc 2) What will it do to a precision expensive device like an injector?
In my opinion based on hearsay and reading, this stuff is only for engines on their last legs anyway. Just a bandaid to get you some miles until you can properly rebuild an engine. I might use it in a gas engine, but I would be worried about the injectors on a diesel, since they are operated by the oil system.
Just my opinion,
Jim Henderson
  #8 (permalink)
Old 01-16-2008, 08:18 PM
BillyBob69's Avatar
BillyBob69 is gaining momentum as a positive member of FTE.
Is there a specific reason you want ot use Engine Restore?
__________________
99 F350SD Lariat Crew Cab
7.3L PSD - 4x4
I got a truck for my wife...Good trade huh?!
  #9 (permalink)
Old 01-16-2008, 08:25 PM
I use it in all my gassers, and was thinking about throwing it in the ol diesel.
  #10 (permalink)
Old 01-17-2008, 08:20 AM
rugermack's Avatar
I'm sorry but i don't think its a bandaid . I would lean more towards a joke. Don't waste anymore of your money on it.
__________________
Patrick
  #11 (permalink)
Old 01-17-2008, 08:28 AM
redford's Avatar
redford has a good reputation on FTE.redford has a good reputation on FTE.redford has a good reputation on FTE.
I guess I would want to know why you use it in your gassers?
__________________
ANG Msgt (ret)
2007 F-250 Super Cab Short Bed 4x4 XLT Sport Package
5.4L 3.73 LS Tow Command and a
Flamed Dashboard Devil Duck
"Drawing on my fine command of language, I said nothing."
Mark Twain
  #12 (permalink)
Old 01-17-2008, 08:33 AM
rugermack's Avatar
On a technical note I really don't see how it could work. If a motor is that bad off it needs to be rebuilt the correct way. I don't like bandaids. I tend to spend the money and do things right. Sorry, just my 2 cents.
__________________
Patrick
  #13 (permalink)
Old 01-17-2008, 10:04 AM
Pocket's Avatar
Someone might find it, but not too long ago I read a report about these oil additives ( I can't remember where I found it). In the study nearly all of them were found to be bad for any engine and stripped the oil of very important lubrication, suspension, and other properties.
A majority of these oil treatments are a joke and for all practical purposes, a scam. There are only a handful that actually did anything, but the cost wasn't worth the minimal gains.
__________________
Curtis
2002 F-250 PSD
  #14 (permalink)
Old 01-17-2008, 10:45 AM
redford's Avatar
This is a good site for learning about oil, additives and all.
http://www.bobistheoilguy.com/
__________________
ANG Msgt (ret)
Mark Twain
  #15 (permalink)
Old 07-16-2008, 06:37 AM
ladelld33 is starting off with a positive reputation.
well i tried it in my 84 f-150 & i don't like it so when i get back from this deployment i'll be changing my oil. i thought about adding some lucus but now maybe not.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
