Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-16-2008, 10:03 AM
countriboi is starting off with a positive reputation.
Cool Engine help?????
I have a 2001 Ford F150 with a 4.2 L V6 engine with 137,000 miles on it. for the most part I cant complain about how well this engine has done for me. I have kept up with the maintenance on the vehicle, changed oil, tune ups, ect. I have also already changes the Air intake Manifold Bolts and Gaskets when they were leaking. anyways on my way into work this AM, My truck started to run bad. It cranked and idled in park fine, It ran fine for about 20 miles, and then it lost power and started missing. It only does this when I am trying to maintain my speed. If I jump on it the vehicle accelerates normally but on occasions I hear a thump sound(almost like a light backfire) when I first push the accelerator down, but then it gets on down the road as usual. As I try to line out and hold a speed that is where it goes down hill. Also The Service Engine light comes on and blinks for a min and then If I let off the gas and just coast along the engine light goes off. I am baffled by this. Any problems I have had in the past the engine light came on and stayed on until it was reset. Anyone out there have any Ideas. I was thinking I may have a bad plug or plug wire. I had a similar issue with the motor before and the sheath of one of the plug wires had melted onto the manifold and was arcing off on the manifold. Have not had a chance to check it out, but would like to know what you guys think? thanks
Brad Hall
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-12-2008, 06:32 PM
MMARSS is starting off with a positive reputation.
I had a similar sounding issue from a '98 F150 4.2 auto. I had decided to replace the wires and plugs when this happened. While replacing the plugs, I found one of them less than finger tight. Apparently, it had backed itself out. Could be simple as that...
j
__________________
2004 F150 XLT Xcab 5.4 3v Auto 4x4
2008 Harley-Davidson XL1200 Nightster
__________________________________
Life's tough. It's tougher if you're stupid.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
