Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-16-2008, 03:04 AM
flcbell is starting off with a positive reputation.
351m to 351c swap
79 F350 4x4 with 4spd tranny. I have a 1971 351C with 4v heads to install in my truck. I do not have the bell housing with the engine. Will this engine work and what do I need.
Thanks much
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-16-2008, 08:10 AM
trinogt is starting off with a positive reputation.
Why not use a 400 crank in your 351M and have a bigger displacement and less work? The 351C uses a different transmission unless you have a rare 400 FMX block from 1973, which has a small block pattern and dual motor mounts.
You can use the 4V heads but only with an intake manifold spacer from Weiand or another brand, and a 4V intake made for the 351C. The 400 is better suited for a truck than a 351, in my opinion, because of the long stroke.
You may also get 302C Aussie quench heads and any 2V intake manifold made for the 351M/400. Better streetability especially for a heavy truck.
The 351C is the same as 351M/400 in design, but the latter has larger main bearing journals, and taller deck, meaning it also needs the wider intake.
__________________
Mark in FL
restoretherepublic.com
  #3 (permalink)
Old 01-16-2008, 09:20 AM
Kemicalburns's Avatar
Kemicalburns is gaining momentum as a positive member of FTE.Kemicalburns is gaining momentum as a positive member of FTE.
save the cleveland for a car. pull the 351m and swap in a 460. its a direct swap and will bolt up to your current tranny. mounts can be found online as well.
__________________
94 XLT 5.8/E4OD
6"ProComp Stage II 35x12.5x15 BFG MT's ,
4.88 gears f/r
installing soon: JBA shorty, Bassani Y pipe, Edelbrock efi truck intake, , aussie front/rear
88 (Rolled)
http://www.supermotors.org/registry/vehicles/detail.php?id=4158
  #4 (permalink)
Old 01-16-2008, 09:10 PM
havi's Avatar
Starting over IS my style
havi is gaining momentum as a positive member of FTE.
Quote:
Agreed. Having an F350 4x4, you want torque. The 351C 4v heads are high rpm hp heads, not low torque street heads. Building the 351M into a 400 is a good way to go, too.
__________________
Foster Brookes was a comic le....leg..lege...genius!Game On!
The Good1948 F1: awaiting an S10 T5 tranny
The Bad1987 TC: awaiting funds for parts
And the Ugly1962 Fairlane: awaiting everything
  #5 (permalink)
Old 01-16-2008, 10:48 PM
Looks like the 351c will be stored for that future stang. Thanks for the input it will be a 400 or 460 swapped in the truck.
  #6 (permalink)
Old 01-16-2008, 11:34 PM
havi's Avatar
stang, tbird, fairlane, etc...by nature the 351C is made to rev. It deserves a car for it to get up and get going to bring it into full flavor. Good choice.
__________________
  #7 (permalink)
Old 01-17-2008, 03:59 PM
Quote:
Well, if you go for the 400, there is no swapping needed, since you have a 351M already. All you need is the 400 guts to put into the 351M (crank and pistons) See TMI forum sponsor for all your 400 needs.
__________________
Mark in FL
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
