Does it only do it when you tried to start the truck? If so that would have nothing to do with the CD player. If you have a crossed wire I would get that fixed. A crossed wire on a CD player would blow a fuse somewhere first, or if you didn't use a fuse then the wire would have melted a long time ago. You need some high current to melt a 4ga. battery cable. I would say you need to check the starter and your grounding to the engine and chassis. Make sure the engine isn't locked up. I had a bad FPR once and it allowed fuel to hydrolock a cyinder so the engine wouldn't turn and I melted a positive cable. Yes this situation can harm the battery if you don't fix it.
Matt
__________________
88 Ranger XLT 4x4, 396W stroker, ZF 5 speed, twin stick NP 205, Perry's Fab n' Fiber fenders & bedsides and hood, 8.8 swap, BII gas tank, lifted a bit, 35in ProComp M/Ts.....4 linked Rockewells and supercharged 557 on the way
