Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-15-2008, 04:35 PM
island-guy is starting off with a positive reputation.
2002 E-350 Single Rear Wheel Hub removal?
I need to change two wheel studs that my tire guy says 'were stripped'. I see you can pound them out with the drum brake pads unloaded but how do you pound them back in? I'm thinking the hub has to be removed but I haven't the slightest idea how...help?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-16-2008, 03:16 AM
kevin-11 is starting off with a positive reputation.
Well if you can get them out with the pounding method, Just slip 2 new ones in and then tighten with wheel on or reverse lug nut to flat side and get enough washers so that when you tighten them it will draw them into place. Just be sure to start them true and straight. And be sure to seat them all the way. Don't go back to tire guy, he is full of it. Always use hand wrench to tighten, this way when it comes time to take them off you don't have to be Hercules to get them off.
  #3 (permalink)
Old 01-16-2008, 03:38 AM
I thought about it but I wasn't sure if it would be too much stress on the bolt or enough to pull it through. You make perfect sense and I will try it, I guess it gets some serious stress while it has a wheel bolted to it with the weight of the van whipping around. Thanks man..
  #4 (permalink)
Old 01-16-2008, 03:46 AM
ford390gashog's Avatar
ford390gashog has a very good reputation on FTE.ford390gashog has a very good reputation on FTE.ford390gashog has a very good reputation on FTE.ford390gashog has a very good reputation on FTE.
To get the hub off unbolt the axle then slide it out.Remove the axle retaining nuts and pull the hub off.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
