anybody deal much with this system? i have the vacumn system with the two servos in back of the intake. both servos seem to be working fine but still throwing the light every two ignition cycles. any help would be appreciated.
That means only one side of the runners are not operating correctly.You can clear it all day long;it won't help.Been there,done that! Sounds like one of the accuators is bad!
__________________ 2007XL R/Cab,4.2 V6,auto
The anticipation of death is worse then death itself!
That means only one side of the runners are not operating correctly.You can clear it all day long;it won't help.Been there,done that! Sounds like one of the accuators is bad! http://www.ford-trucks.com/forums/50...highlight=IMRC
