Leak at master cylinder and brake booster
My truck is leaking brake fluid in between the master cylinder and brake booster. I got on autozones website to see it there was a gasket in between the two, and couldnt find one. So I did some more searching and one guy told me it was proabably a seal inside of the master cylinder. So if this is the case should I just by a rebuild kit for it, or a whole new one?
on
F250's come in two flavors, over and under 8600 GVWR. If your door tag is still there, it'll be on there. If it's an ex cab, it's probably a HD, if it has a 460 or diesel it definitely is. If it has a full floater rear, it probably is a HD.
The single/double probably refers to the calipers, but, I think the LD F250's have duals also. Could also be referring to the booster being single(under 8600) diaphragm or dual(over 8600.)
If it's been leaking for any amount of time, I'd suggest buying both, they are available as an assembly, and I think it's around $100 or so.
Be careful on my 82 I found out there are 3 master cylinders available. The light duty single piston, middle duty double piston and over 8600lbs. Make sure you know otherwise you will spend more time running than anything. If you have the inbetween master cylinder don't try to use the over 8600lbs one. The fitting are different and I was unable to make it work. I found out the hard way.
brian1080
07-28-2016 10:30 AM
banned
21
07-26-2011 08:39 PM
Stewart_H
05-13-2010 03:55 PM
cjf5150
58
11-23-2006 09:20 AM
