Block heater
Block heater
Its get'n cold here this week (low- teens) & I'm getting ready to start using the block heater again. Ran into a problem w/ our new house - no wall plugs in the garage. Garage & house are connected by a breezeway - no breaker box in the garage just the two opener outlets overhead & a couple of outside lights. That's all.
I didn't even think about plugging the trucks in until now or I'd already have run a 2cnd line out to the garage - looks like that will have to be a spring project but in the mean time... How long of an Ext cord can I run? - its probably 35ft to the nearest outside outlet on the house. The two outside outlets (luckily) are on 20A breakers - just opposite corners of the house. Neither are close to the garage. Bummer....
Last place we had I installed X3 20A single outlets & assoc breakers for each of the 3 vehicles - When I get to it I plan to do the same here but it'll probably be well into Feb before I could do it - I need a temporary solution that won't burn the house down.
DG
DG
I have safely run a 12 guage 200 foot cord. If you are going with a long length of cord, just make sure you have a good, high quality cord that can withstand the amps your truck pulls. Get a 10 guage if you can find one - They are expensive!
Something like this would be good if you only have 35 feet to go:
http://www.amazon.com/Coleman-Cable-50-Foot-Extension-02688-88-02/dp/B000A3I3GA/ref=sr_1_28?ie=UTF8&s=hi&qid=1200413120&sr=1-28
Or: http://www.amazon.com/Woods-50-Foot-T-Blade-PowerLite-2991/dp/B000HEC2DW/ref=sr_1_56?ie=UTF8&s=hi&qid=1200413427&sr=1-56
Originally Posted by dagren99
Thanks, I'm going to hit Home Depot on the way home tonight.
If they don't have a 10awg I'll probably go with the Coleman Cable one you listed.
DG
DG
mustang_gt_350
44
03-11-2013 03:19 PM
