Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-15-2008, 10:05 AM
JCastellaw is starting off with a positive reputation.
Fuel Tank Selector Valve
Is the selector valve a 180 degree turn to change tanks?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-15-2008, 03:59 PM
play400 is new and has a neutral reputation at this point.
Yep but I'd put in an electric switch instead. Got tired of the sucker always leaking a tad when switching tanks.
  #3 (permalink)
Old 03-10-2008, 08:52 PM
reamer's Avatar
reamer is starting off with a positive reputation.
Where to get this electric switch?
  #4 (permalink)
Old 03-10-2008, 10:17 PM
RCrawler's Avatar
RCrawler is gaining momentum as a positive member of FTE.
Pollak # 42-159. I have one that I'm not using that I will make you a deal on if you want it. I ended up not using the 2nd tank. You can also get new manual tank switch valves that don't leak.
Jason
__________________
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
'79 F150 4wd lwb 400, 435, 205
"You can take the boy out of the trailer park, but you can't take the trailer park out of the boy."
  #5 (permalink)
Old 06-06-2008, 10:40 PM
you still have that electric pump crawler?????/
  #6 (permalink)
Old 06-08-2008, 10:57 PM
RCrawler's Avatar
Quote:
$20 plus shipping and you can have it. I could not PM you.
Jason
__________________
  #7 (permalink)
Old 08-16-2008, 09:42 AM
74broncosport's Avatar
74broncosport is starting off with a positive reputation.
I got amanual switch from broncograveyard a while back. its 90 between tanks so it doesnt match the indicator plate.
Where did you get the electric?
Thanks
__________________________________________________
05 F-150 SCrew Lariat 5.4L
76 F-100 360/C6
74 Bronco Sport 302
73 Ski Nautique 351
  #8 (permalink)
Old 08-16-2008, 09:58 AM
Nevermind. I found it on pollak's site. $50. a bit steep. I'll deal with the mismatch.
76 F-100 360/C6
74 Bronco Sport 302
73 Ski Nautique 351
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
