Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-15-2008, 02:07 AM
johnperdeye is starting off with a positive reputation.
dtc's what do these mean
p0263 and p1000
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-15-2008, 02:38 AM
doubledee715's Avatar
doubledee715 is starting off with a positive reputation.
0263= cylinder 1 contribution/balance fault
1000= monitor checks not complete-more driving required.
__________________
David, 2003 f250 6.0 cc sb Centennial Edition, Dieselsite coolant filter, afe stage 2 w/pg7, ejf1000 edge juice w/attitude replaced w/innovative tuned xcal, blocked off egr cooler, Quadzilla Commander w/pillar mount, ARP studs, ITP RR, 05 accufab elbow, 4" tb, pic
  #3 (permalink)
Old 01-15-2008, 09:54 AM
ok what does that cylinder 1 contribution/balance fault mean
  #4 (permalink)
Old 01-15-2008, 10:20 AM
69cj is starting off with a positive reputation.
You should list your equipment in your signature. More people would help you if they didn;t have to go to your gallery to figure out what your driving!
__________________
"05 F-250, CC, LB, 3.73, Lariet, with coolant filter and Bilstein shocks, S. Ca.
"69 Mustang, Mach 1, 428 CJ, Ram Air, Stock
"71 Triumph Trident
2007 Thor Jazz 5er, 11k, 31'
  #5 (permalink)
Old 01-15-2008, 10:47 AM
ok will do
__________________
04 f250 cc sb fx4 6.0 bullydog triple downloader, leveling kit and more to come
  #6 (permalink)
Old 01-15-2008, 01:16 PM
Mark Kovalsky's Avatar
Mark Kovalsky has a great reputation on FTE.Mark Kovalsky has a great reputation on FTE.Mark Kovalsky has a great reputation on FTE.Mark Kovalsky has a great reputation on FTE.
Quote:
Originally Posted by johnperdeye
04 f250 cc fx4 bullydog triple downloader, leveling kit and more to come
Engine? Transmission?
__________________
Mark
Former Ford automatic transmission engineer, 1988-2007.
  #7 (permalink)
Old 01-15-2008, 01:50 PM
and how many miles
__________________
  #8 (permalink)
Old 01-15-2008, 01:51 PM
im no tech but I'll guess that that code means that cylinder 1 wasn't contributing what it should have been.
__________________
  #9 (permalink)
Old 01-15-2008, 02:41 PM
npccpartsman's Avatar
npccpartsman is gaining momentum as a positive member of FTE.npccpartsman is gaining momentum as a positive member of FTE.
It means that the computer detected cylinder #1 as not outputting the same as the rest. On my truck it usually means an injector, usually a bad spool valve. The P1000 is a relearn code associated with disconnecting the batteries or reprogramming. It will go away after "X" number of drive cycles have been performed.
__________________
I BLEED RAZORBACK RED
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
