the window..you did it right..that's what i had to do when i replaced the passenger window.
Hp...Is the Cat Converter clogged?
Power for radio..just run some power straight from the battery or find a source that comes on only when the key is on.
__________________
-Jeff
86 Bronco II 4inch suspesnion lift, 3inch body, 35x12.50x15 BFT AT/s and 4:10gears.
05 F250 Superduty Diesel--tows the BII to the trails
