Quote:
Originally Posted by angus
Maybe the pressure switch isn't rated to handle the current that the pump motor draws. Get a 30 amp automotive relay and wire it so the pressure switch activates the relay, and the relay switches the pump motor.
I'm not much of an electrician. The addition of the relay means I will need to run another wire, right?
Right now I have a power wire from a switch in the cab going to the compressor. I have a second hot wire going from a switch in the cab to the horns. I have a ground wire from the horns to the chasis and a ground wire running from the compressor to the chasis. That last one is the one that the pressure switch is tied into.
I'll sit down with the relay. Maybe it will be clear to me as I look at it.
