Brake Controller Fuse and Relay Question - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 01-14-2008, 05:43 PM
kailor's Avatar
kailor kailor is offline
kailor is starting off with a positive reputation.
I will be installing a Prodigy brake controller soon. I traced the 3-wire bundle from the 4-flat connector on the rear bumper back a couple of feet to the driver's side frame. From that connection, toward the front of the Expedition, I can see the bundle of wires that include the blue wire and the orange(?) wire. I've yet to locate the gray, six pin, three over three plug under the dash for the brake controller harness. My Expedition did not come with the Tow Package. Do I have a brake controller harness plug or am I looking for something that is not there or possibly in a location other than above the OBDII plug? It's very tight getting in there to take a look around. I think I might be overlooking it.
Also I've checked my fuse/relay module under the hood by the master cylinder and I'm missing these:
Half Relay # 203 "Trailer Tow Backup Lamp Relay"
Full Relay # 302 "Trailer Tow Battery Charge Relay"
Do I need these two relays for proper operation of the brake controller?
Thanks.
Old 01-14-2008, 06:54 PM
cachingcampers cachingcampers is offline
cachingcampers is starting off with a positive reputation.
If your Expy doesn't have the tow package, you won't have the connector for the prodigy pigtail. On my Expy it was actually clipped on top of the OBD port. If it's not right there, then no luck.
On the relays, you WILL need the charge relay if you have a battery on your trailer, otherwise the +12v pin in the 7 way bargman will be dead. It was funny, the dealer told me it was obsolete( I bought the Expy used and was missing this relay) I did a little research, found it to be the same relay as the fuel pump, PDl and etc....callled the same dealer back, gave him the part # and low and behold he had 2 in stock.
The back up lamp relay is an axillary circuit primarily used for slide in truck campers. You won't be needing that one.
I just got my expy all set up for towing my trailer, so it's all fresh in my mind. Any questions just fire away.
Old 01-14-2008, 07:09 PM
kailor's Avatar
Thanks cachingcampers. If no brake controller harness plug, should I have this done at dealer or an RV place?
Old 01-14-2008, 07:23 PM
I dunno........depends how handy you are. The prodigy is pretty simple install just 4 wires, +12v/ground/brake sense input/out to trailer. You will need to find a +12v circuit somewhere under the dash,not hard with the fuse box right there, a good ground,again not that hard to find with all that metal around, a wire diagram/test light to find which wire activates the brake lights when you hit the pedal, then you'll have to run a wire all the way to the rear bargman for the electric brakes.........sounds like alot of work, but I've wired mine up on several other non-tow package vehicles over a couple of cold ones!
Hope this helps.
Greg
Old 08-11-2008, 11:26 AM
SPRPRBGT SPRPRBGT is offline
SPRPRBGT is starting off with a positive reputation.
do you know the parts umbers for the relays? and where can i get the harness for the controller. my used '00 didnt come with it
Old 08-11-2008, 05:27 PM
Eddie Hudson Eddie Hudson is offline
Eddie Hudson is starting off with a positive reputation.
Quote:
I recently purchased part # XL34 15A416 AE on eBay. It has both relays, the harness for the brake controller, and a 4 pin to 7 pin adapter. I've seen them sell for $1 - $20 on eBay. I guess Ford would charge quite a bit more. The harness plugs in under the dash near the steering column and you splice it to your controller. I don't know the numbers off the relays but as stated, one is the same as the Fuel Pump Relay.
My 2001 has a 4 pin connector in the rear and when I traced it back it went to a connector that had the extra wires for the 7 pin connector. If I ever dig up a 7 pin harness, all I have to do is remove the 4 pin and install the 7 pin.
Hooking up Primus IQ trailer brake controller enriquemo2 Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 1 06-08-2015 08:02 PM
Reverse lights stay on after installing the Trailer relays, Help! Two000F250 1997 - 2003 F150 1 09-07-2013 04:04 PM
'97 E250 trailer wiring location Handegard Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 1 07-18-2013 09:23 AM
'97 E250 trailer wiring location Handegard 1968-2013 Full Size Vans 1 07-17-2013 09:14 PM
Trailer Brake control Frankievespa Excursion - King of SUVs 2 04-11-2011 10:56 PM
Tags
15a416, 2000, ae, backup, brake, controller, diagram, f250, ford, fuse, lamp, location, part, relay, xl34, xl3415a416ae
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
