Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-14-2008, 03:42 PM
fireman660r is starting off with a positive reputation.
Injector Driver Module fried..
Started my truck on a cool morning this weekend. It was sitting there warming up for about a minute, and then about the time it would kick up to high idle it died. Tried to start it, wouldn't fire. After some looking I found the IDM fuse under the hood burnt out. Went to store and got a couple more. When the key was just turned to start the glow plugs the fuse would pop. Had truck towed to dealer on sunday. Tech looked at it this morning. Found a shorted out Injector Driver Module. My tech and service writer are good friends and know I have my programmer. They told me they had to send the programmer into Ford for warrany reasons. Before the tow-truck got called I reprogrammed the truck back to stock. I did not unhook the batteries however. I am curious if Ford is going to find anything on that module or not. Service writer is also thinking maybe the programmer caused the short in the module, I don't think so, but I am curious if any of the Spartan guys know about this for sure or not. Thanks
__________________
Uhh? What he said.
2005 F350 FX4 Lariat. 6.0 PSD, CC, SWB. Quadzilla commander. MBRP 4" turbo back w/ stock cat. SCT xcal III w/ Matt's custom tunes. ARP headstuds.
1995 Bronco XLT. Jet black on grey leather. 4" ProComp lift, 33" BFG MT's.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-14-2008, 03:46 PM
SpartanDieselTech's Avatar
FTE Sponsor
SpartanDieselTech has a great reputation on FTE.SpartanDieselTech has a great reputation on FTE.SpartanDieselTech has a great reputation on FTE.SpartanDieselTech has a great reputation on FTE.SpartanDieselTech has a great reputation on FTE.SpartanDieselTech has a great reputation on FTE.
FICM's have been known on an unfrequent basis to just up and fail at random times; not a frequent problem but a known one.
The SCT does not program the FICM in any manner (I wish it did, but it doesn't). so far as far as any relation, it isn't possible.
Correct me if I read wrong, but they made you send the programmer into Ford? From a warranty standpoint, there is no way I would have allowed such if I was the owner of the truck, especially since you returned it back to stock before hand.
__________________
Visit the Spartan Diesel Technologies Website
Matt Geouge
  #3 (permalink)
Old 01-14-2008, 03:56 PM
adambomb's Avatar
adambomb is gaining momentum as a positive member of FTE.
Quote:
PSD 60L Fx4 FICM's have been known on an unfrequent basis to just up and fail at random times; not a frequent problem but a known one.
I myself recently just found out the hard way that this is true. I hope for your sake that it gets warrentied because a new FICM and labor is pricey. We both have '05s, I wonder if this is a coincedence?
I don't know if you have checked my tread, but i started having problems soon after my FICM was replaced.
http://www.ford-trucks.com/forums/68...ay-diesel.html
I am still looking for that fricking chaffed wire!!!
__________________
2005 6.0L F350 Lariat CCLB FX4
Dynomite Diesel 90hp Injectors
ARP Studs/Racing Gaskets
Spartan SCT X3
Banks Techni Cooler
FASS
AFE Stage I Intake
4" MBRP Turbo Back Exhaust
AutoMeter PhantomII Boost/Pyro/Trans Gauges
2.5" ICON Suspension*35" Xtreme AT's*18"KMC Monsters
  #4 (permalink)
Old 01-14-2008, 05:08 PM
wrangler76 is starting off with a positive reputation.
The FICM Harness was a recall item on my '04. It was recalled because they were shorting out on a bolt. If it's recall due to mechanical failure I imgaine they would be hard pressed to proove it as a result of aftermarket programming.....
__________________
Adam
Carson, WA
"Meller Yeller" - '79 F-350 4x4 Supercab, Built 356 series
'04 F-250 4x4 Supercab, 6.0 PSD
  #5 (permalink)
Old 01-15-2008, 02:34 PM
Sorry Matt, I typed that in wrong. They sent my module in for the warranty, NOT the programmer. I picked up my truck this morning, everything is fine. Not sure what they will find, but if the SCT will not touch the FICM then I should be in the clear. I will check your thread next Adam, I hope I don't have anymore problems. Thanks guys.
__________________
Uhh? What he said.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
