Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-Atlantic Region > West Virginia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
West Virginia Chapter Join Chapter, Leader: msgtg
  #1 (permalink)
Old 01-14-2008, 10:23 AM
swickg331 swickg331 is offline
Garage is empty, add now
swickg331 is starting off with a positive reputation.
how do I make in-tank fuel pump work?
For those that have done the efi to carb conversion on the 87-91, did you use the low pressure in-tank fuel pump and if so, how did you wire it to work without the computer.
thanks
  #2 (permalink)
Old 01-14-2008, 05:40 PM
Archion's Avatar
Archion Archion is offline
Trained Parts Monkey
1996 Fleetwood Wilderness
My Garage
Archion has much to be proud ofArchion has much to be proud ofArchion has much to be proud ofArchion has much to be proud ofArchion has much to be proud ofArchion has much to be proud ofArchion has much to be proud ofArchion has much to be proud ofArchion has much to be proud of
Archion.Uberpimp PartsGuyMatt mvose OVC Archion
To get it to work, you "should" (my memory is a bit fuzzy) just need to power the relay, like the computer did, you can use the in tank pump, but still need a regulator before the carb. The in tank pumps out out more than the carb can handle alone, like 20 -35 psi and all you need is 8-10 at most, more likely 5-7. You will have to remove and/or bypass the frame mounted high pressure pump.
__________________
Matt - Ninja Edit Master
02 Excursion XLT V10 4WD - 12 Escape L4 XLT AWD - 99 Mustang 3.8L 'Vert - 96 Wilderness 22LW TT
JOIN THE WEST VIRGINIA CHAPTER CLICK HERE
Carlisle - 2012 Mid-Atlantic Meet - Pic Thread >>CLICK ME<<
  #3 (permalink)
Old 01-15-2008, 05:10 AM
I plan on using a regulator, but if I'm not mistaken I think the in-tank pump puts out somewhere around 8psi. They are used to get the fuel to the high pressure pump on the frame rail. These trucks have 3 pumps, 1 in each tank and then 1 on the frame rail. As far as I can tell from the wiring diagram the power comes from the ECM to the inertia shut off to the tank selector switch to the pump. I figured if I can supply a switched power source before the inertia switch everything should work just fine. Thanks for your help guys
  #4 (permalink)
Old 01-15-2008, 06:33 AM
msgtg's Avatar
msgtg msgtg is offline
1992 Ford F-150
My Garage
msgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to behold
Good Luck Pal!
Joe
__________________
03 F250 King Ranch Crew 6.0 4x4 92 F150 XLT SuperCab 4x2 03 Intruder Volusia 03 Ranger XLT
WV Chapter Lead JOIN THE WEST VIRGINIA CHAPTER CLICK HERE
We live in the Land Of The Free...BECAUSE of the Brave! My humble thanks to all Veterans, past and present
Tags
2004, conversion, ford, fuel, intank, make, pump, pumps, specs, tank, work, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
