Best way to build serius power, im talking 800-1000 HP - Ford Truck Enthusiasts Forums
Old 06-30-2002, 09:17 PM
460RV 460RV is offline
460RV is starting off with a positive reputation.
Old 07-05-2002, 03:33 AM
Mistro Mistro is offline
Mistro is starting off with a positive reputation.
I plan on getting into street mod truck pulling and am torn wether to go with a 460/429 type motor or go with the 427 FE motor. I was looking for the best combo to go with if price wasnt a big determining factor (hey, if Im gonna do it im gonna do it right, not halve-azzed) Who makes the best heads, intake and all that stuff. I dont have no expierience with the 460 being only 16 but my current truck has a 390. Thanx. my plan is to start accumulating parts and in a few years I can take out a loan and really get going. Thanx
Old 07-05-2002, 04:33 AM
phantom429 phantom429 is offline
phantom429 is starting off with a positive reputation.
Well I think the best way to go is to use the 460 block. The 427 is an engine that is a lot more expensive to build with the horsepower numbers you seek. Besides the pure coolness and nostalgia of a 427 between the fenders of a cool old ride is far more appealing than as a rat race motor.
From what I have gathered from this forum you can look at spending 20-30K for a bullit proof monster. Your lookin at-
-500cui stroker with billet crank, real good rods, forged pistons that can handle the horsepower you want.
- Big bucks for heads, sounds like ported SVO heads are a sure bet.
- Oh ya amd a big honkin cam, let alone the countless support peices like racing style high capacity oil pan, roller valvetrane, etc...
- From what I have learned a 460 block can only handle 650-700 horsepower max???
One could build a wishlist as long as a freight train!!!!:-X12
Old 07-05-2002, 04:36 AM
Oh ya and nitrous oxide.... lots of it!!!
Old 07-06-2002, 01:53 AM
daywalker daywalker is offline
daywalker is starting off with a positive reputation.
>train!!!!:-X12
Ford Motorsport offer a crate motor built on a 2bolt main remanufactured 460 block that makes 600hp. It's a 514 stroker. I'd say a 4 bolt main would be able to handle it. The SVO 460 block can take 1500hp at 8kRPM or 9kRPM.
Old 07-06-2002, 08:40 AM
georgedavila georgedavila is offline
georgedavila is starting off with a positive reputation.
Racers run 2-bolt blocks to 650-700hp on a regular basis with no main bearing walk problems.
Old 07-06-2002, 05:00 PM
9Volt 9Volt is offline
9Volt is starting off with a positive reputation.
i would run a 4 bolt main 460 block from SVO, stroked to 806. then twin turbo the ****, and add lots of nitrous. should net you about 1750-2000 hp
or, what i would really do, is run a 600 cube stroker on twin turbos, no nitrous. for a truck pullin motor you want a lot of low and mid range TORQUE. so thats what we should be talking here, not hp. torque, torque, torque will be the name of the game. and nothing builds low end power like CUBIC INCHES and smaller sized turbos that spool up quickly.
id stay away from the NOS because you really shouldnt run it in the lower rpms, and because it has a tendency to blow up a motor.
i wouldnt run supercharged either, because for the amount of power that they add for the cost, you could have with twin turbos for a lot less.
almost forgot, look for a motor with a longer stroke than bore. this combo also spells low end torque, albeit a lower revving motor.
Old 07-07-2002, 02:46 PM
Actually you need top end HP, around 8000 rpms to keep wheel speed up. And you cant run power adders either. the guys on the FE forum know more about how to make a power with a 460 than you guys on the 460 forum.
Old 07-07-2002, 03:15 PM
It's not that we don't know how to make power, It's that we don't need to. The 460 engine make soo much power on their own with bolt-ons that any more power would cause a rift in the space time continuim. :-x10
Nick from the frozen north
1974 F-250 4X4
soon to be 429
dana 60 front and rear
Old 07-10-2002, 03:06 PM
ultimatebronco ultimatebronco is offline
ultimatebronco is starting off with a positive reputation.
http://www.crateengine.net/460605.html
Look here this might help
Old 08-06-2013, 08:38 PM
RoofManMike RoofManMike is offline
RoofManMike is starting off with a positive reputation.
Aluminum Blue Thunder Heads
Here's MY bored 460 motor 1000HP Build:
472 C.I. FORD Roller
13 to 1 / J&E Pistons
Steel H Beam Rods
726 Roller
ALUMINUM BLUE THUNDER Heads
VICTOR 460 Intake
1150 HOLLY DOMINATOR
This ran 8.63 in the 1/4 in a small fox body w/out NOS
It's so MEAN it lurches forward when I start it like it wants to eat you. The slicks are studded to the rims. You wanna make a monster, the 460 is your ticket.
I'm currently researching Diesel engines for my mint 89 F-250 2wd, to be discussed in its own thread, for now kid, get you a 460 and bore it out. Nothing beats the rumble of American made Detroit MUSCLE.
Old 08-14-2013, 06:28 AM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
monsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputation
wow what's up with dragging up 10yr old threads LOL
Old 08-15-2013, 10:42 PM
4.9L 4.9L is offline
4.9L has a good reputation on FTE.4.9L has a good reputation on FTE.4.9L has a good reputation on FTE.
Build a forged BBF stroker, AFR heads, toss a ball bearing T88 on there, nice intercooler, spray a 200 shot, and have a second setup of nitrous to either spray the turbo to help it spool or spray the intercooler to make the boost (AIR) colder
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 04:27 PM
ooops Aerostar 5 01-14-2015 04:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 07:14 AM
delete 97puller Ford Truck Parts for Sale 15 04-08-2014 05:53 PM
test jr105 Testing..... 0 04-04-2014 09:10 AM
Tags
1000, 1000hp, 351c, 460, 500cui, 800, a460, block, build, cost, fe, ford, horsepower, hp, max, small
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
