Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-14-2008, 09:08 AM
HateTank is starting off with a positive reputation.
"Click" when trying to start, then lights/accs go dead
Hey all,
When trying to start up my 81 E350 school bus the other day, all that happened was a single, loud "click" and then all my power shorted out (headlights go dead with the click). This is a louder "click" than I usually hear when a starter solenoid goes (i replaced it anyway). I couldn't pinpoint where exactly it was coming from, since I was alone.
***I noticed that after the click/power loss, if I go to the battery and twist the pos. batt cable on the terminal. I get a crackle of power @ the terminal and all my lights come back on. -and, the pos connector is warm (yes, the cables/terminals are clean) It's as if a circuit breaker has been tripped when I try to start it. and I reset it by a little twist at the terminal. Of course, it just clicks again/ goes dead when I try to start it afterwards. (I'm sure it's not a loose battery cable thing)***
3 weeks ago I put a new starter in it (well, autozone) and it has been running fine ever since. The vehicle has been parked inside and completely undisturbed since it was last started with no problems (about a week ago).
1)Checked battery twice -it was good. (even tried a different one known to be good)
2)Replaced the starter solenoid -no effect
3)Checked cables -visually ok, and all connections clean and tight
My only last thoughts are:
- That new starter decided to quit for no reason (btw, I have not yet directly applied batt power to it..... I just disconnect the starter lead from the solenoid and touch it to the pos terminal, right?)
-A fusable link broke for no reason
Thanks
__________________
77 F-100 SuperCab
81 SW Schoolbus
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-14-2008, 10:16 AM
alexchavel is starting off with a positive reputation.
grounds
Sounds like you have a problem with grounds.
I rebuilt an old 1979 e150, everytime i have this click problem or problems starting, it's usually loose, missing, or bad grounds.
Look over ALL your grounds, clean surfaces, tighten.
This is often overlooked, people think solenoid or else first, but for my van its always grounds.
  #3 (permalink)
Old 01-14-2008, 05:32 PM
rclarke is starting off with a positive reputation.
Remove the battery cables from the battery and scrape the post and the inside of the cable clamps to bright metal then replace them and tighten firmly.
  #4 (permalink)
Old 01-14-2008, 07:38 PM
mhg mhg is offline
mhg is starting off with a positive reputation.
what rclarke said
you have already found the problem
the pos. bat cable
if you can twist it its loose and must be tighter
__________________
2003 bull 3.0 24v stock
1996 E-350 351
  #5 (permalink)
Old 01-15-2008, 11:11 AM
Yup, that was it... battery cable. Problem solved.
Thanks all.
__________________
77 F-100 SuperCab
81 SW Schoolbus
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
