GVM of F250 L/D vs H/D
For several months I've been trying to buy a local 1982 F350, unfortunately this has fallen through.
I'm looking now at the possibility of shipping an F250 across to New Zealand.
Regulations here require any L/H drive vehicle to be converted to R/H if the manufacturer's GVM rating (vehicle weight + payload) exceeds 3500kg.
Can someone give me the GVM figures for both the Light & Heavy duty versions of the 80-86, 2WD F250's?
What were the significant differences between the two - chassis, axles, general durability etc? Were any years particularly better or worse?
Thanks very much
Thanks very much
Thanks very much
Thanks very much
If you want to purchase locale (Dunedin), I have a 1984 F250 4x4, cab & 1/2, 6.9L Diesel that I would consider selling. Very good condition! Mint deck, only 100K miles etc.
gary.mcneill@stonebow.otago.ac.nz
In the 80-86 Ford F series the only difference in GVW was the rear ends & springs. The Frames are the same. Ford Made a what was called a light F250. It had 8 lugs but wasn't a full floater rear end. The rest used Full floater rear ends. Then they built an F250 with the basic 1 ton suspensions, these came with the diesel option.
