Highboy np205 linkage?
Old 01-14-2008, 02:53 AM
78fordf150ranger's Avatar
78fordf150ranger
78fordf150ranger is offline
I would like too know if anyone has any pictuers of a np205 divorced shift linkage
Old 01-14-2008, 03:22 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
Is it a NP435 or C-6 you need help with? I know the NP435 but I have also seen divorced setups with the C-6. The NP435 was easy the shifter mounted with 2 bolts on the rear drivers side tail housing with 2 rods . It was a simple setup I will try to take a picture for you.
Old 01-14-2008, 04:30 AM
78fordf150ranger
its a c6 auto
Old 01-14-2008, 04:45 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by 78fordf150ranger
its a c6 auto
Mil1ion is the only member that I know of who can post illustrations of the linkage.
The illustrations are in the CD version of the 1973/79 Ford Light Truck Parts Catalog. Mil1ion can scan and post, but there's 4 different illustrations.
Need to know: Year of the truck, the model, and is it full or part time? Do you have a part time transfer case, or a full time?
Old 01-14-2008, 04:49 AM
NumberDummy
With or without part time drive?
What year and model do you have?
There are four different illustrations of the linkage.
Mil1ion has the parts catalog on a CD, he can scan and post, but will need the correct reference.
Need to know the right combo before I can give the pic page numbers and sections from the parts catalog
Old 01-14-2008, 05:29 PM
78fordf150ranger
part time np205 divorced on a 76 ford f250
Old 01-14-2008, 11:57 PM
NumberDummy
transfer case shift mechanism ~ A/T ~ P/T
1973/79 Ford Light Truck Parts Catalog / The exact illustration > >
Ask FTE member Mil1ion to scan and post the following:
Illustration = Section 70 / page 6
A CD Copy of the above parts catalog is available from: hipoparts.com
Old 11-10-2008, 02:23 AM
stewart460's Avatar
stewart460
stewart460 is offline
I have been looking for the linkage for 3 months now It's for a 77 F250 with an auto c-6 and divorced np205 with part time 4 wheel drive any suggestions where to find it
Old 11-10-2008, 06:06 AM
bucks77ford's Avatar
bucks77ford
bucks77ford is offline
Old post dug up. Welcome to FTE. Your best bet, Junkyard.
Old 11-10-2008, 07:56 AM
lostinfords's Avatar
lostinfords
lostinfords is offline
Is that a single linkage or dual and are they the same for a manual trans., w/ the mntng hdw. being different? I am only asking because I may have one from a '74 f250, but it is just 1 piece.
morning Pat!
Old 11-10-2008, 08:45 PM
75F350's Avatar
75F350
75F350 is offline
NP205 has only one rod (unless the "twin stick" modification has been performed) and the NP203 has two.
These are crazy easy to make.........
Old 06-01-2014, 08:25 PM
TrippingCobras's Avatar
TrippingCobras
TrippingCobras is offline
Anyone ever find the bushings part numbers?
I have everything else, but the bushing are worn pretty badly, not good for a frame off restoration. I'll turn one out of brass on a lathe if I have to, but I'd rather just buy one.
Old 06-02-2014, 02:45 AM
NumberDummy
If you're referring to the T/C shift lever bushings...
2) EOTZ-7335-C (replaced D3TZ-7335-A) .. Transfer Case Gearshift Lever Bushings / Available from Ford.
Applications: 1973/87 F100/250 4WD / 1978/87 Bronco.
Pic from 1973/79 Ford Light Truck Parts Catalog ~ Bushings are shown as basic part number 7335.
Old 06-02-2014, 10:01 PM
1972RedNeck's Avatar
1972RedNeck
1972RedNeck is offline
Originally Posted by bucks77ford
Old post dug up.
And you thought 10 months was old.
Old 06-02-2014, 10:25 PM
redroad's Avatar
redroad
redroad is offline
nevermind
Quick Reply: Highboy np205 linkage?
