Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 01-13-2008, 10:57 PM
customcab66's Avatar
customcab66 customcab66 is offline
1966 Ford F-100
customcab66 is starting off with a positive reputation.
1967 ranchero
Is there anyone else out there building a 1967 fairlane ranchero?
__________________
Allen D. Jr
1966 Custom cab truck
1967 Fairlane Ranchero
Oregon Chapter Member: To join the Oregon Chapter, click HERE
  #2 (permalink)
Old 02-01-2008, 08:19 PM
1ton460bronco 1ton460bronco is offline
Garage is empty, add now
1ton460bronco is starting off with a positive reputation.
we built one a few years ago and my dad drives it everyday outside of the winter
  #3 (permalink)
Old 02-01-2008, 08:47 PM
ford_boy_1996's Avatar
ford_boy_1996 ford_boy_1996 is offline
ford_boy_1996 is gaining momentum as a positive member of FTE.ford_boy_1996 is gaining momentum as a positive member of FTE.
yeah I built one last year
__________________
Tony G
96 F-250 HD 5.8, 5speed, 4.11's, 8ft MM plow
1994 Mazda b2300 2.3L 5-speed 2wd gas saver
1989 Mustang 5.0 5speed 3.73s
  #4 (permalink)
Old 02-05-2008, 12:14 PM
tfowler306's Avatar
tfowler306 tfowler306 is offline
tfowler306 is starting off with a positive reputation.
My little brother has one he has been working on for about 4 years now... off and on..
  #5 (permalink)
Old 12-17-2008, 03:06 PM
hitower4 hitower4 is offline
hitower4 is starting off with a positive reputation.
Quote:
I'm building a 66, same basic body but a falcon front end.
It now has a 5.0, 5 speed,sway bars front and back, flowmaster 2 1/2" exhaust, Headman header,Eldelbrock 600 carb and performer manifold, 3.25 gears.On the Hot Rod Power Tour last the car averaged over 20 mpg and over 25 mpg on the hiway. Have fun building and driving your car.
  #6 (permalink)
Old 04-19-2010, 10:17 AM
flibo1967 flibo1967 is offline
flibo1967 is starting off with a positive reputation.
yes i am ,i just bought it out of bradenton fla. im doing the front end first all suspension parts, then the steering box, then on to the rear end,then the interior ,then the 289 4v and t-10 4 speed, dave
  #7 (permalink)
Old 04-21-2010, 08:02 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by flibo1967 View Post
yes i am, i just bought it out of bradenton fla. im doing the front end first all suspension parts, then the steering box, then on to the rear end.
then the interior, then the 289 4v and t-10 4 speed, dave
Welcome to FTE
No Borg Warner T-10's in Fairlanes after 1965. As original, it would have had a Ford 4 speed top loader.
btw: The correct way is: Mechanical work first, paint/body work second, interior last.
If you restore it the way you've planned, the new interior could get greasy...or worse.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #8 (permalink)
Old 04-21-2010, 11:17 AM
well the body is done and painted, interior is probably 90 % done, the car came with a three speed from the factory,the guy i bought it from installed the bw t-10, im not building it to resale or anything like that, im building to go 1/4 mile at a time, it should b a fun project. im probalby 6-10 months away from my goal, then when im done with it ,who knows ill probably build something else, thanks for the info though, dave
  #9 (permalink)
Old 07-11-2012, 01:54 AM
kenk71121 kenk71121 is offline
kenk71121 is starting off with a positive reputation.
67 Fairlane Ranchero 500XL Rear Suspension
Hi FTE,
I just picked up a 67 Fairlane Ranchero 500XL 390/C6. I am going through the entire vehicle. Started & finished the front end brakes & suspension. Im now beginning the rear suspension. I cannot see where you access the upper rear shock mounts . Please dont tell me there is an access panel in the bed. Previous owner had bed Rhino Lined and i'm sure it is not easy stuff to remove;.
Any and all assistance is greatly appreciated.
Thanks,
Ken
  #10 (permalink)
Old 07-11-2012, 02:44 AM
Ford Parts Guru
2013 Ford Escape
Shock mounts to bracket below spring pack, then thru hole in crossmember. There's no upper shock bracket. Above the hole, just bushings, nuts and washers.
Shown here: 1965/72 Ford Passenger Car Parts Catalog / Illustration Section 54 / Page 4.
This catalog is available on a CD from hipoparts.com
__________________
  #11 (permalink)
Old 07-11-2012, 03:15 AM
Thanks Number Dummy, But how do I get above the hole to put on the bushing/washer/nut??
  #12 (permalink)
Old 09-11-2012, 12:18 AM
52 Merc's Avatar
52 Merc 52 Merc is offline
1952 Mercury M-1
52 Merc has a great reputation on FTE.52 Merc has a great reputation on FTE.52 Merc has a great reputation on FTE.52 Merc has a great reputation on FTE.
Quote:
Originally Posted by kenk71121 View Post
Hi FTE,
Thanks,
Ken
Unfortunately for you, there is a large access panel in the floor of the bed that accesses the top of the shock absorbers.
Click the image to open in full size.
__________________
Wayne
52 Mercury M-1
among other things.
Tags
1966, 1967, 67, bronco, built, custom, david, end, ford, leslie, ranchero, rear, roadster, specs, truck, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
