For 54" thornbirds Id say he needs another 2" body lift 2" front lift blocks and stacked 3" blocks in the rear. That should clear fine. It wont matter though because either A- you will be killed going to the bog hole with that chitty steering setup or B- the second you put in in 4wd the d44 front will snap or C- the basturd will catch on fire.
or D, as soon as the tires hit the mud, that high class body lift will shear off and launch the body into the mud like it was a boat being christened.
If I had to guess on the body he stacked two 3" kits, but who knows where he got bolts that long.
Now thats a good lift! 4X6's are sturdy and bolted on with lag bolts! I bet this lift would only run $20 in installed! And for you mud guys just swap the 4X6's for treatred ones!
Again i say smack his mom. Window lickers like that are why off road trucks have a bad name. They should crush that thing like they did that Honda in Florida.
Is that a wheel chock or did one of the lift blocks fall out? I guess he spent all his money on those bogger stickers and couldnt afford the real thing.
Ghunt,
where did you find that pic? Please tell me you didnt take it yourself!
Nah, I didn't take that picture. Got it from a guy on a Mustang board I go to, who lives up in Canaduh (notice Canada Post on the one sign in the background)
ROFL! Thats funny
Looks like stuff off the scary steering page... If you havent seen that before, I suggest taking a look for some good entertainment!
Well, I wasn't going to add onto this topic because I had nothing good to say, but, what can you say about a Bronco II with 2 1/2 axles and a 3" body lift ....
#220192493137
You know it always starts with the 3" bodylift
Then it is the steering
Who needs vacuum advance when you have a 125 HP shot of NOS!
Better hurry up before someone meets the $15,000 reserve
