Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-13-2008, 04:24 PM
D.J D.J is offline
D.J is starting off with a positive reputation.
fuel pump?
i have fresh fuel filters and will not start. so i took the fuel pump off and it seems to be working. there is fuel in the secondary filter. i have also blew through the lines and they are not clogged up. maybe the pump is weak. any ideas
thanks in advance
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-13-2008, 04:26 PM
D.J D.J is offline
there is not fuel at the secondary filter
  #3 (permalink)
Old 01-15-2008, 12:22 AM
F250tuff's Avatar
F250tuff is starting off with a positive reputation.
Check the o-ring on your primary filter cap? It sounds like you don't have a good seal and the fuel isn't making up to the secondary filter.
__________________
'06 F250 PSD CC Fx4 Lariat
  #4 (permalink)
Old 01-15-2008, 04:20 AM
bismic's Avatar
bismic has a very good reputation on FTE.bismic has a very good reputation on FTE.bismic has a very good reputation on FTE.
After changing the fuel filters, make sure you use the proper procedure (cycling your key on and off) to pre-fill the secondary fuel filter before you attempt to start the truck.
__________________
Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20
DieselSite Coolant Filter; High Idle Mod
Zoodad/Air Fury grill; Accufab Elbow; CCV filter
Fumoto; HFCM Plug; Harpooned fuel tank
JimmiJammers; Ravelco; DashDaq & britebox on deck
Line-X, CPOhighway Prod. tool box, tracrac
Fox Weatherboots; Wet Okole Seat Covers
Stanadyne Perf. & B2 for lubricity
  #5 (permalink)
Old 01-15-2008, 05:25 AM
B327Thr is starting off with a positive reputation.
Did this start immediately after filter replacement or days later? I usually turn the key on twice for 30 seconds a piece and it starts right up.
  #6 (permalink)
Old 01-15-2008, 09:00 AM
moebdick's Avatar
moebdick is starting off with a positive reputation.
There is an inlet valve in the HFCM that is opened when that filter is seated as the cap is replaced. Be sure the cap seats fully against the lip (don't overtighten).
__________________
2004 F250 Lariat CC, 4X4 PSD
  #7 (permalink)
Old 01-15-2008, 10:36 AM
69cj is starting off with a positive reputation.
1. Are you using Racor filters or aftermarket filters. Some A/M don't fit correctly.
2. Always lube the O-ring with motor oil, not fuel prior to torqing. Fuel can swell the O-ring and cause a leak.
3. The cap must be fully seated but not over torqued.
__________________
"05 F-250, CC, LB, 3.73, Lariet, with coolant filter and Bilstein shocks, S. Ca.
"69 Mustang, Mach 1, 428 CJ, Ram Air, Stock
"71 Triumph Trident
2007 Thor Jazz 5er, 11k, 31'
  #8 (permalink)
Old 01-15-2008, 09:31 PM
D.J D.J is offline
thanks guys it ways days later. i use luber finer l4604f fuel filters. another thing i was running wvo. worked great for about 4 tanks of running 100%. it was just a little harder to start. i'm gonna go through the hfcm tommorow to see if the inlet valve is clogged. i was thinking the pick up screen in the tank was clogged so i pulled the tank and it is clean. i'm was just wondering because the pump works just no fuel flow.
  #9 (permalink)
Old 01-15-2008, 10:50 PM
bismic's Avatar
I do not think that Luber Finer makes Racor style fuel filters. You may want to stick w/ filters from International - at least replace them this time and see if it resolves the problem. Be sure to fill / purge the system before cranking.
__________________
Mark
  #10 (permalink)
Old 01-16-2008, 12:08 AM
LvTitan is starting off with a positive reputation.
last secondary filters i bought didn't really fit well either...
__________________
04 6oh... that's where the money went.
  #11 (permalink)
Old 01-16-2008, 06:46 PM
D.J D.J is offline
it is for sure the pump is bad. got one on the way. thanks for the help guys
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
