Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-13-2008, 03:42 PM
broncobeater is starting off with a positive reputation.
Question which engine should i use
I have an 85 bronco2 with a 2.8 that has lost spark.I also have a 2.9 out of a 89 that i scrapped complete with wiring harness and brain that will run. Which would I be better off with?My 85 has the 5 speed manuel and lockouts.Will the 2.9 even fit this trannsmision? I'm not sure but I love the little broncos.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-13-2008, 05:15 PM
Help I M Stuck is starting off with a positive reputation.
the 2.9 will work..hopefully you kept the exhaust headers for the 2.9. You'll need to put a fuel pump in the tank or swap in a tank with one already in it. Hopefully with that 2.9 you have EVERTHING..heads/intake/exhaust... It WILL bolt to the transmisison.
__________________
-Jeff
86 Bronco II 4inch suspesnion lift, 3inch body, 35x12.50x15 BFT AT/s and 4:10gears.
05 F250 Superduty Diesel--tows the BII to the trails
  #3 (permalink)
Old 01-14-2008, 08:58 AM
I stripped all the usable parts so I should have everything I need.Thank You
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
