Compression check
Compression check
I just ran a compression check on my 460 with D3VE-A2A heads, and all cylinders are holding steady at 120 PSI. I know the compression ratio is 8 to 1, but what should I be at in PSI? I've searched this site for articles pertaining to compression measured in PSI, but have had no luck. Any help would be much appreciated. Thanks
Compression check
Thanks, that's a great site, but I don't have the barometric pressure. And even if I did, there's no telling that that reading would be normal for my engine. I'm wondering if anyone has done a compression test on a stock 460 and what pressure they came up with in "PSI". It seems to me that my reading of 120 is a little low for a 460, but I'm not sure.
Compression check
When new they cranked up from between 150-175 psi.
[font color=red]Dennis
FTE Adminstration
[/font]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
64 1/2 Mustang Pre-World's Fair Car #8092
68-Mustang 289 2v-Sunlit Gold
[/font]
FTE Adminstration
[/font]
[/font]
Compression check
120 PSI doesn't sound too bad. At least it's consistant. I wish mine was. But judging from the previous posts mine seems pretty good considering the mileage, except for one cylinder. My 460 has 125,564 miles on it now and my compression check with the D3VE A2A heads reads 150 psi in all cylinders except in one, number four which reads 120 psi. Yes it was checked with the engine warm and WOT. I have put some Marvel Mystery Oil in the crank case in and effort to hopefuly free up a possible sticky valve or lifter which might give me my a low reading in number four. I haven't done a compression check yet to see if it has done any good. Maybe at the next oil change. I have a set of D0VE heads on the back burnner that I hope to get put on after the summer. Then hopefully I can get a little better than 6 MPG. :P
Compression check
I sent this to somebody, but guess I didn't post it.
14.7 is the sea level atmospheric conversion rate for calculated compression ratio to psi.
'74 + - 8.0:1 x 14.7 = 117.60psi
'72/73 - 8.5:1 x 14.7 = 124.95psi
'68-71 - 10.5:1 x 14.7 = 147.0psi
'68-71 - 11.0:1 x 14.7 = 161.70psi
Sea level atmospheric pressure is just that. If you test at a higher elevation or in weather conditions with fluctuating barometic pressures, it changes the calculation. The higher the elevation, the thinner the air. NHRA has a conversion chart for elevation. This is the reason serious racers have mobile weather stations, so they can adjust their fuel jetting based on barometric pressure and humidity, which affects combustion.
GuitarJesus
05-05-2016 07:28 PM
MONAVIERONJON
06-12-2013 09:00 AM
Purely Ford
10-21-2004 01:20 PM
