Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-13-2008, 01:28 PM
nhbound104 is starting off with a positive reputation.
Coolant filter system
Would this be a good idea for my 06 f350, to cut down on future probems?
If so, what's a good make?
Thanks
__________________
2006 F350 CC
2005 Ranger
2005 Freestyle (Wife)
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-13-2008, 01:38 PM
npccpartsman's Avatar
npccpartsman is gaining momentum as a positive member of FTE.npccpartsman is gaining momentum as a positive member of FTE.
It's an EXCELLENT preventative measure for these trucks since casting sand seems to be one of the culprits for oil cooler/EGR cooler failure. Dieselsite.com has an excellent kit for about $120 (last time I looked anyway).
__________________
I BLEED RAZORBACK RED
  #3 (permalink)
Old 01-13-2008, 02:52 PM
Powerstroke_wannabe is gaining momentum as a positive member of FTE.
I second that recommendation.
__________________
Frank
2006 F250 Lariat FX4, CC, SB, 6.0 PSD, Torqshift, 3.73 LS, Backseat DVD system, Peragon Folding Bed Cover, Extreme Bedliner, Westin Bully Bar, Dieselsite Coolant Filter, Fumoto Valve, Accufab Intake Elbow, Bilstein HD Shocks, Smitty-Bilt Grille Inserts, MBRP Turbo Back Cool Duals, Kitty ran away
  #4 (permalink)
Old 01-13-2008, 03:08 PM
hd4ever is starting off with a positive reputation.
Hi
Would this void the warranty?
  #5 (permalink)
Old 01-13-2008, 03:46 PM
There's no possible reason it should void the warranty. Ford should actually EXTEND your warranty for you putting it on there--IMHO.
__________________
  #6 (permalink)
Old 01-13-2008, 08:02 PM
indyraven is starting off with a positive reputation.
It is a FANTASTIC idea. If you get one, just wait until you see all the gunk it filters out! I built mine with parts from Napa, but unless you are kinda handy with fabricating a bracket for the filter holder, dieselsite.com is the way to go.
  #7 (permalink)
Old 01-13-2008, 08:09 PM
Momorris is starting off with a positive reputation.
I bought mine from Dfuser.com. It was $160 but it came with 3 filters and two ball fittings which make for a fairly dry filter change. Relatively easy install, just a lot of coolant loss when you cut that first hose.
  #8 (permalink)
Old 01-14-2008, 09:25 AM
UGA33's Avatar
Yeah Come On!
UGA33 is gaining momentum as a positive member of FTE.
I lost only a teaspoon of coolant b/c i used a buddy. He held the lines at an upwards angle while i cut and hardly any coolant was lost. Definately get the fittings!
__________________
2006 F-250 Lariat Crew Cab Shortbed FX4
-Josh-
*6.0L PSD*MBRP Turbo-back*35" BFG Mud Terr. KM2's*Leveling Kit w/ Daystar Coil Spacers & Rancho RS5000's*Spartanized SCT X3*Autometer EGT & Tranny guages*Coolant Filter*CCV Reroute*F-350 blocks*High Idle Mod
  #9 (permalink)
Old 01-14-2008, 11:56 AM
HeavyAssault's Avatar
HeavyAssault is gaining momentum as a positive member of FTE.
I got the Dieselsite.com kit and was really impressed with the overall quality and fit of the parts. +1 for this mod!!
__________________
'06 F-350 Crew PSD 4X4 ESOF 3.73 AUTO
Some stock stuff, some modded stuff, some "deleted" stuff
  #10 (permalink)
Old 01-14-2008, 12:00 PM
bradcollison is starting off with a positive reputation.
+ 2 for this mod.
I have the Dieselsite setup and it is really well engineered.
I'm lucky I have a relatively clean system to start with. Put mine on at 15,000 mi. Just some casting sand is what I've seen.
My Degas bottle does look cleaner now!
  #11 (permalink)
Old 01-14-2008, 03:41 PM
720Deere is starting off with a positive reputation.
The coolant filter is an excellent idea. Don't buy your kit from Dfuser. He advertises the Baldwin non SCA charged filters but ships Fleetguard SCA charged filters. A 4 unit SCA filter is too much for the size of the Powerstroke cooling system.
The Baldwin CFB5000 filter head can be had on ebay for about $35, the B5134 filters can be found likewise for about $9/ea and the fittings and hose can be found at just about any auto parts store for less than $20. Add another $15 for ball valves from Home Depot if you so choose and you still have spent less than $100. You will need to fabricate a mounting bracket for the filter head, but that's not a big deal either.
If you want to purchase a "kit" go with Dieselsite because they have the best price and will send you the correct filters.
  #12 (permalink)
Old 01-14-2008, 04:45 PM
rollerstud98 is starting off with a positive reputation.
if i'm pushing 120k miles without egr cooler failure or oil cooler failure do you think that this filter would really benefit me enough to justify the cost of it?
  #13 (permalink)
Old 01-14-2008, 05:37 PM
ozx3+1's Avatar
And the price is paid
ozx3+1 is gaining momentum as a positive member of FTE.ozx3+1 is gaining momentum as a positive member of FTE.
Quote:
I did mine after the EGR and Oil coolers failed... I had no choice. The spend was easy...
Product Description Price Quantity Total
2003-2007 6.0L Coolant Filtration System
$119.00 1 $119.00
Coolant Filter Ball Valves
$17.96 1 $17.96
http://www.dieselsite.com
Tell Bob I sent you
Blessings-
Brian
__________________
Brian
  #14 (permalink)
Old 01-14-2008, 05:38 PM
EZ-Ford's Avatar
EZ-Ford is starting off with a positive reputation.
I installed the filter from Dieselsite, included the 2 shut-off valves. Was VERY simple. Did not loose ANY coolant, because I drained out about 2 gallons first. After the install, simply add it back in. IMO, very good insurance for adding life to the engine, EGR, and water pump.
__________________
'06 F250 PSD ExtCab LB SRW Auto - And Loving It.
Installed Upfitters, BCP High-idle, Bi-Pass Coolant Filter (DieselSite), Zoodad, Fomoto
+12V 30A Service to Rear for 'toys'
8oz PS Diesel Kleen in every tank
  #15 (permalink)
Old 01-15-2008, 03:59 AM
bismic's Avatar
bismic has a very good reputation on FTE.bismic has a very good reputation on FTE.bismic has a very good reputation on FTE.
Quote:
Originally Posted by hd4ever
Hi
My dealership (head of service department) is very picky so I asked them if they would make an issue of the coolant filter. At first, he figured I didn't know what I was talking about since he hadn't heard of one. After I showed it to him, he said it would be no problem. It would have to be a very unreasonable dealership that made an issue of this.
Many folks, including myself, have removed a lot of grit with it. The oil cooler, I have heard, can still plug up even if you run one of these filters so it is not a "cure all pill". It is a GREAT add on for reducing wear and tear that results from circulating this grit and casting sand. The first couple of filter changes had the most in it, but the casting sand can slough off slowly after many miles. Just routinely check to make sure the filter still has flow by making sure it is hot after you have driven awhile.
__________________
Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20
DieselSite Coolant Filter; High Idle Mod
Zoodad/Air Fury grill; Accufab Elbow; CCV filter
Fumoto; HFCM Plug; Harpooned fuel tank
JimmiJammers; Ravelco; DashDaq & britebox on deck
Line-X, CPOhighway Prod. tool box, tracrac
Fox Weatherboots; Wet Okole Seat Covers
Stanadyne Perf. & B2 for lubricity
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
