Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 and SOHC 4.0 V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-13-2008, 12:46 PM
mediaman67 is starting off with a positive reputation.
Plugs and Correct Gap
Hi All,
Here is an easy one for all of you :-)
I have an explorer with the 4.0L OHV
anyone know the correct gap for MC plugs and Autolites as well? does that change if I run a Double Plat vs a Single?
The dealership gave me single Plat MC's - saying that was OEM - will Double Plats give me anything better, other than longer life? do they run hotter?
also, does anyone know the coil pack pairs? are their 3 of 2 plugs each? or does every Cyl have it's own single coil?
I'm running MC wires btw
Thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-13-2008, 04:18 PM
Moore558's Avatar
Moore558 is starting off with a positive reputation.
You didn't say what year your explorer was, but I believe the spark plug gaps on the OHV 4.0 would be between .052-.056 . As for the single vs. double platinum goes I've heard of people running the double plats with good success and no problems. The double plats would last a little bit longer but that would be about it in my opinion. If you've got single plats you can go ahead and use them without problems. As for the coil packs, there are 3 packs combined into one with 2 plugs per pack.
Hope that helps.
__________________
Farewell Baby. You will be forever missed. 03-29-96 to 07-16-2008
  #3 (permalink)
Old 01-13-2008, 05:50 PM
do you know which packs control which 2 sets of cylinders? - it would be great if one pack was for cyld 1+4 - would explain a lot :-)
  #4 (permalink)
Old 01-13-2008, 06:43 PM
Moore558's Avatar
There should be numbers on the coil pack that identify which 2 cylinders that individual coil is suppose to fire. If I remember the coil numbering goes like this.
3 6
2 5
1 4
Front of Engine
So in this case it would be 1-4, 2-5, 3-6 would be the 3 ignition coils and what coil controls what. The 142536 is also the firing order. The cylinders are also numbered in the same manner as the coil firing order above, so hopefully that helps.
__________________
  #5 (permalink)
Old 01-13-2008, 08:31 PM
Hi, ok... this is a dumb question - but where are the packs located? under the cap that has the wires? how do you get to them for replacement?
Thanks,
  #6 (permalink)
Old 01-21-2008, 08:14 PM
B-Aerostar's Avatar
B-Aerostar is starting off with a positive reputation.
But check the coil for proper placement because its labeled 123 left 465 on the right
35
26
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
